    Mar 2002
    manchester, UK
    hi, newbie here.
    I just found out nero isn't really good for this kinda thing. I want to break out of just doing a straight video, and add menu's, chapters, which nero can't do.
    the files i get are all vcd/svcd compliant, so making them isn't the problem.
    From what i can tell, vcdeasy&cdrwin is the easiest option for what i want to do?
    I also have ulead dvd Moviefactory.
    Which would be the better/easier option.
    I only want to do a basic menu, and simple chapter selection.
    here's the other query. I had a dvd->vcd conversion. all the chapters have been split to seperate vcd compliant mpeg's. is it possible to create a menu that allows access to each mpeg as a seperate chapter? Or do i have to merge them all into one, and create entry points?
    again, would dvd Moviestudio be the best option for this?
    Thanks in Advance! :)
  2. Yeah, you should be able to do this in VCDEasy. I don't know about the other programs. Refer to my new guide for details: http://forum.vcdhelp.com/viewtopic.php?t=84327
    But basically on the "Interativity" page, check "Overwrite this default assignment". Now you can define a chapter sequence (1=1st mpeg, 2=2nd mpeg, etc.). I'm not sure how smoothly it will play from one mpeg to the next, though.
