Results 1 to 13 of 13
    Sep 2011
    New Delhi
    I want to create a vcd of length 92 minutes. Is it possible to create the same in a single 700 mb CD? I m using VCDEASY 3.0. If yes plz advice me proper avi to pal vcd converter which reduce the size of mpg video.
    Nope. VCD is a constant size, https://www.videohelp.com/vcd#tech
  3. Member Cornucopia's Avatar
    Well, although I have never interpreted it this way, the user "VCD4ever" assumed that the standard spec bitrate on VCDs was a MAX, and that if you had no problem with any possible lowering of quality, you could provide a bitrate lower than that max. Since the BR would be lower, you could conceivably fit 92 minutes.
    I don't recommend this. I've always gone under the assumption that the spec reads: CBR @ 1150kbps (IIRC). Some players might accept lower, but I'm pretty sure that some players would NOT.
    IIWY, I'd try breaking the title into 2 discs.
    I also have to ask...It's almost 2012 - do you really still need VCD???
  4. Originally Posted by Cornucopia View Post
    He's in India where VCDs still sell like hotcakes. But I agree with you - it's still a dumb idea. Just make a DVD.
    Sep 2011
    New Delhi
    I have been creating DVD since 2005 but some clients need vcd for their lower budget project. Anyway I have tried lots of way but failed.
  6. DECEASED
    Jun 2009
    Heaven
    If you accept to go thru the "non-standard" ways, then yes it's possible to create a 2-hour long VCD
    (depends a lot on on the source's compressibility AND on the eye of the beholder, of course) .
    However it's quite probable that most/all VCD-only hardware players will solemnly refuse to play such discs
    Therefore, either use 2 CD-Rs (as Cornucopia has recommended), or author a DVD.
  7. Member dragonkeeper's Avatar
    Jul 2003
    Seems like you have three options.
    1. Create a 2 two disk.
    2. Create a vcd on DVD or better yet svcd on DVD.
    3. Convince your customer that vcd is going the way of the dodo and DVD would better suit their needs.
    I don't know about India but at this point in time it would cost my clients more for me to create a VCD than to author a very basic DVD. (Main menu with a play button.) The price difference between printable DVD media and and printable cdr media is negligible. I have often seen cdr media cost more than DVD media, so where is the savings to your budget minded customers?
    Not to mention that it appears that fewer and fewer players support vcds. Out of all the blu-ray players and DVD players I currently have, I believe only the Phillips supports VCDs. Things may be different in India though.
    Murphy's law taught me everything I know.
    Jul 2001
    Not sure if they're available in your area, but there used to be '90 minute' CDRs. Might have been some 99 minute ones too... don't think they were very dependable though. You could lower your bitrate and fit your 92 minute video, or, just find 2mins of video to cut.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    they don't work with vcd/svcd because of the sector numbering used to create oversized discs.
    you can't change the bitrate of vcd video, it's 1150kbps or it's not vcd.
    Aug 2005
    Palo Alto, California USA
    As others have said, a truly vcd-compliant disc will not run longer than about 80 minutes on a standard CDR. Deviation from the standard will generally introduce problems with some fraction of players. If that doesn't bother you, then you can reduce both audio and video bitrate (or either alone). Achieving a 92 minute run time is a trivial task. Quality suffers as you push to longer and longer times, but then again, no one should expect high quality from VCD, so perhaps that's not such a big deal. If you're unhappy with the end result, keep lowering expectations until you're satisfied.
    These off-spec VCDs are generically referred to as "XVCDs" in most places. TMPGEnc is a popular tool for doing the encoding, and VCDEasy is a popular tool for authoring. Countless users have happily produced low-res discs with these and similar tools.
    Mar 2008
    What about the old Tmpgenc 2.5 and the KVCD templates.
    This used to work pretty good at these extended length non-standard VCD's.
  12. Member Cornucopia's Avatar
    Well, if you still have the same VCD/DVD player that worked with those non-standard burns, there's a good likelihood that it will still work.
    However, times have changed.
    What I'm seeing in most NEW DVD and BD players is that if they support VCD at all (which is becoming quite rare), it's only the files/burns that are fully compliant that work. Which is what we've been saying...
    To sum it up: It really doesn't make much sense to sacrifice long-term viability for short-term all-on-one convenience.
    Mar 2008
    I'm not the OP, I only mentioned it as a possible option . I did a few, and they certainly worked on the three players I had at the time!
