Hello,
I'm not finding many solutions here in the USA. Looking for cheap or basic printer that will allow me to print directly to CD/DVD.
Are DVD backups so resolute. I hate having my backups look like there illegal, most of these are kiddy flicks that I don't wont the original to be destroyed.
I can find maybe one or two printers that have this feature.
Any suggestions?
No.
I think us Americans are stuck using either Epson Printers that come with the optional CD/DVD Printing Tray (currently the cheapest option),
or springing for the highly expensive (and oddly, usually lower quality) other options. -
I have had much success with the Epson Artisan 810. The internal CD/DVD loader is alot more convenient and less frustrating than the manual tray loader in the older models. Not sure what you consider cheap, but $200 for something I get a lot of use out of is a pretty good deal. I know you said basic, but it is fax/printer/copier. Plus if you buy the TY DVDs with watershield, the backups look almost identical to a pressed DVD (Except for a ring around the outer edge).
For cheap? Get any of these Canons used (I recommend the iP3000 - the last one I bought on Kijiji.ca was $5 and it works great). Do the tray mod and get a tray off eBay. One of the best parts is a whole set of carts will only set you back $8 (last generation of chipless carts).
What printers print on Blu-ray inkjet printable media?
By videobread in forum MediaReplies: 4Last Post: 23rd Dec 2010, 19:08 -
Do you see a Blu-ray DVD recorder in the market?
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 4th Sep 2010, 18:29 -
Printers for Putting a Label Directly on a DVD Surface
By solarblast in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2009, 21:04 -
Dvd printers Dymo
By ultraman36 in forum MediaReplies: 6Last Post: 20th Dec 2007, 18:07 -
New DVD recorders trickling out on the market
By DVWannaB in forum DVD & Blu-ray RecordersReplies: 0Last Post: 17th May 2007, 16:47
