I have Win 32 bit on my C drive. I bought 64 bit but I'm a bit 'worried' and want to make sure things will run properly. Here's my question:
Can I do a fresh install on another drive (My D drive is currently very empty). And if all works well, use that drive as my boot drive and then wipe the C drive after moving all my valuable information over to the D drive?
Smile
Smile -
I would temporarily unplug the C boot drive. I've had problems with using a 'D' or other drives for OS boot with some programs. Your empty drive will become your 'C' drive then.
You can move over your data from the old 'C' drive if you plug it back in, though it will probably be the 'D' drive now. You can't easily move programs, just data.
I usually unplug all hard drives except the boot drive when installing a OS. If all your drives happen to be the same size, you can easily format the wrong drive and destroy all your data.
Good to know. I'll move all my important files over to one drive (I have 3), unplug 2 and then wipe the already clean drive for a fresh install. Hope it works.
Smile
Smile
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 17:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 11:12
