  1. Member RogerTango's Avatar
    Nov 2007
    I have 2 drives, one has XP and one has W7. I would like to have both hooked up and select OS on power on.
    What software/method would you suggest?
    I have an Asus M2V motherboard if that helps...
    Thanks,
    Andrew
    Feb 2004
    Australia
    Generally none in the case of two separate drives ... just use F5 and select the required drive to boot from.
  3. Member RogerTango's Avatar
    Nov 2007
    Thanks for the F5 tip... Ill give it a try!
    Andrew
