I need some answers please. I've had this problem for a Long Long time.
So I download an mkv movie online. And I convert it to mp4 in order to downsize and to be able to put it and play it Off my external hard drive.
The mkv file has dts audio 6.1.
I use handbrake on my Mac to convert it.
On the settings for audio, I choose aac and Dolby pro logic II bitrate 160.
This is my problem , my audio in mp4 file always is kinda low.
Like, during the movie when it comes to a part where the actors are only talking , the sound is really low. So then I put up the volume. But then when theres some loud action in the movie, the sound is a little too loud , so I have to put the volume back down.
So during the whole movie, I'm constantly putting the volume up and down , up and down on my tv.
I'm am pretty sure it's in my conversion settings that give me the problem. I just dont know much about the different codecs. Hopefully someone knows what I am talking about. Can anyone help me find the correct settings?
I only have that problem with my mp4s that I create
When I play avi files that I get online,that I don't need to convert, the sound is always fine.
Let me know if you need anymore info. I use handbrake for my conversions and I only have a Mac.
Try the handbrake beta/nightly builds and you can adjust the gain, download from https://build.handbrake.fr/view/Nightlies/
Audio Gain Control initial implementation
Adds a Circular Slider to implement gain from a range of -5 to +15 which is sane by any reasonable measure. -
what do u mean the gain?
I really dont know much about this audio stuff.
Thanks for your help. -
Adjust the volume. Increse the gain to increase the volume.
But you really need a "normalizing/normalize" feature, increase the low volume and reduce the high. But that wont you find in handbrake. I don't know easy all-in-one solution in the mac world. Most audio editors has that feature....but it's seems like a lot of work for just to watch movies. -
ok. so i should just try and adjust the gain . thats the easiest and fastest thing i can do .
i will try it and see what happends
MKV to MP4 audio stretch issues!!!
By wphill in forum Video ConversionReplies: 3Last Post: 18th Jul 2012, 07:42 -
Playing HD MP4 Files From Disc Playback Issues?
By zombie1 in forum DVD & Blu-ray WritersReplies: 5Last Post: 5th Nov 2011, 12:41 -
MPEG to MP4 audio synchronization issues.
By BlooderButcher in forum Video ConversionReplies: 0Last Post: 5th Oct 2011, 20:48 -
Fixing Out of Sync Issues with Mp4 files?
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 14:01 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 07:56
