    Jul 2011
    sofia
    Hi guys, I need some help over here. I have an anime in mkv format. Here is the nfo of the file
    Video
    Format : AVC
    Format/Info: Advanced Video Codec
    Format profile: High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames: 8 frames
    Muxing mode: Header stripping
    Codec ID: V_MPEG4/ISO/AVC
    Nominal bit rate : 1 500 Kbps
    Width: 1 280 pixels
    Height : 720 pixels
    Display aspect ratio: 16:9
    Frame rate: 23.810 fps
    Original frame rate : 23.976 fps
    Color space: YUV
    Chroma subsampling: 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame): 0.068
    Writing library: x264 core 98 r1629 2e81ce1
    Encoding settings: cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=3486 / vbv_bufsize=3487 / ip_ratio=1.40 / aq=1:0.50 / nal_hrd=none
    Audio
    Format : AAC
    Format/Info: Advanced Audio Codec
    Format profile: LC
    Codec ID: A_AAC
    Channel(s): 2 channels
    Channel positions: Front: L R
    Sampling rate: 44.1 KHz
    Compression mode : Lossy
    Text
    Format : UTF-8
    Codec ID: S_TEXT/UTF8
    Codec ID/Info: UTF-8 Plain Text
    Using mkvtoolnix I'm extracting 3 files : "name.h264" , "name.aac" and "name.ass".
    Using Yamb I'm trying to create an mp4 file but the are no subtitles when I play the video file and the audio isn't synchronized with the audio. Question : how to fix the audio and subtitles problem? Is there any other program I can use to create an mp4 with synchronized audio/video/subtitles?
  2. Member dragonkeeper's Avatar
    Jul 2003
    Try using subtitle workshop to convert to srt.
    Murphy's law taught me everything I know.
    Jul 2011
    sofia
    yes but it is creating *.mkv and I want .mp4
  4. Member dragonkeeper's Avatar
    Jul 2003
    My bad Try using subtitle workshop to convert the subtitle to srt.Then mux with YAMB.
    Jul 2011
    sofia
    Yes, that's what I'm doing - extract with mkvtoolnix (ass) , translate & save in to name.srt (subrip).
