Hi All,
My 3 year old Acer laptop has failed recently. I was wondering if possible to find a desktop motherboard that support Intel Core2 Duo M and notebook RAM ?
Thanks in advance.
I think you're looking for a socket 479 or socket p motherboard. Many Micro ATX and Mini ITX boards used to use that.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100...on=479&x=0&y=0
http://www.google.com/search?q=%22socket+p%22+motherboard&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US
fficial&client=firefox-a#q=%22socket+p%22+motherboard&hl=en&client=firefo x-a&hs=fzE&rls=org.mozilla:en-US
fficial&prmd=imvnsfd&source=univ&tbm=shop&tbo=u&sa =X&ei=CIGtTpfwGKqyiQKi_aCvCw&ved=0CEkQrQQ&bav=on.2 ,or.r_gc.r_pw.,cf.osb&fp=f099214307952858&biw=1170 &bih=773
But given the prices you're probably better off just dumping the parts.Last edited by jagabo; 30th Oct 2011 at 11:55.
Probably better to sell the laptop, whole or in bits, and buy PC parts.
Maybe some laptop repair shop will swap them for you. -
Dead Laptop and using the Win 7 activation key
By Moontrash in forum ComputerReplies: 8Last Post: 29th Oct 2011, 11:22 -
Substitute a USB audio device for dead laptop soundcard? [SOLVED]
By usually_quiet in forum ComputerReplies: 14Last Post: 2nd May 2011, 00:17 -
Philips 3575H with dead IR receiver--can I salvage the HDD?
By Valeriavictrix in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 13:36 -
Can I salvage this AnyVC file?
By milkydoo in forum Video ConversionReplies: 2Last Post: 16th Sep 2009, 01:03 -
Laptop charger dead
By Tbag in forum ComputerReplies: 21Last Post: 24th Dec 2008, 17:55
