I have an .avi movie where the dimensions are 632x480. Can that at all be converted to 720x480, where it will look decent, and made into a DVD, or will it look bad?
Well, it can be easily converted to DVD video. As to whether or not it'll look any good, there are too many variables to be sure - how decent is the AVI quality to begin with, the type of display you'll be viewing the DVD on, the bitrate used, etc. etc. No way to know but to try using AVS2DVD, DVD Flick, etc.
How about a movie where the dimensions are 720x304? Would it be good to run the file through the software you mentioned?
Whatever software you use, just be sure to use the right combination of scaling and padding to get the correct image proportions.
If the file was recorded off TV as 480i, it can be horizontally stretched to 704/720 wide without affecting interlace. Any vertical resize would first require inverse telecine back to progressive.
http://www.kiva.org/about
Software for editing a converted “VHS to DVD” then burning a new DVD?
By TinCanTheClown in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2011, 20:58 -
What are the exact requirements for a video to be AVCHD complaint ?
By ahmadka in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Jun 2011, 20:24 -
Non Hdcp complaint probs! with Phillips Dvp5980/5
By hangman960 in forum DVD & Blu-ray PlayersReplies: 13Last Post: 13th May 2010, 14:48 -
converted AVI to DVD, VIDEO_TS is created, but once on DVD, movie is green
By jens.3 in forum ffmpegX general discussionReplies: 3Last Post: 18th Dec 2009, 01:43 -
Recorded DVD-RW on DVD camcorder...Converted file to .wmv but not working!
By annabelle88 in forum Video ConversionReplies: 3Last Post: 16th Sep 2007, 08:04
