I'm rather new at Win 7-64, as I started running it mostly because of my editing program Avid Media Composer. The program opens alright, but with no video. So I guess the question is probably a codec problem. What codecs should I install with Win 7-64?
Most of us would likely advise to just install the codecs you need or are working with.
A few codecs have 64bit versions. But you also need a 64bit app that can use them. I don't know about Avid.
Many of my programs only run in 32bit mode. If I have 32bit codecs installed, normally no problem. I do run W7 64bit. With 64bit or 32bit programs, and codecs, they need to be installed in the proper Windows directory, 64bit or 32bit. -
Subtitle Workshop doesn't have a 64-bit version, I believe, so you'll need to use 32-bit codecs. Use MediaInfo on the videos you're trying to open in Subtitle Workshop (if they're AVI or MPEG, you can also use GSpot), and see which video codec each uses, then install the necessary codecs.
You can probably just install the 32-bit version of ffdshow and enable the relevant codecs (in both the VfW and DirectShow video codec configuration dialogs). However, since you're using Win7, you may also need to use the Preferred Filter Tweaker.If cameras add ten pounds, why would people want to eat them? -
OK. Stage two. Following some directions I found on the web I could install SW and it did work for a few days, as it should.
But since yesterday Windows 7 started working weird. It stopped seeing srt files as associated to SW and I can't make W7 to open srt files with it. No matter what I do.
I reinstalled SW and nothing.
It only works if I run SW and then open the srt file from it. Runs with video and fine. But it's the wrong way to use it.
I wonder what might be happening and what can I do to solve it.
Backwards running
By Zenner in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:41 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
Newbie question for adding subtittle to ripped MKV
By yd8552 in forum Blu-ray RippingReplies: 2Last Post: 29th Oct 2009, 17:59 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 23:51 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59
