Hi folks,
I am currently working on a video that requires different filters in different scenes (using Virtualdub for this project). For this reason, I have split the episode into segments and applied the filters to each segment accordingly. My plan is to then rejoin the saved AVI segments with Virtualdub. No problem so far.
Here's my concern:
I understand that loading a video with Virtualdub and saving it as an AVI does not result in loss of quality, as it is uncompressed (using Huffyuv). When I take my saved AVI segments, reload them into Virtualdub (for the purpose of joining them), and save them again as a new AVI, would I THEN begin to lose quality? If it is true uncompressed, then I assume the answer is no. However, I am aiming for professional results and want to make sure I'm not missing something.
Thanks in advance![]()
I've never had that understanding.I understand that loading a video with Virtualdub and saving it as an AVI
If you set it as encoded with HuffyUV, then that might be so. Default is RGB, quite a different codec.
But if you save the filtered file as an uncompressed video, HuffyUV or Lagarith, then they should retain their quality.
Of course if you re-encode to another format, you would have quality loss. That would mostly depend on the conversion format you use. But using a lossless format should keep the quality until you re-encode. -
Gavino, my eyes must be giving out on me or something. Can't find the subject at all in the link you gave, unless I'm missing something! I have VirtualdubMPeg2. Could you please sort of guide me on where I should go in Virtualdub in order to find filter curves?
I appreciate it. -
I don't know about VirtualDubMpeg2 (isn't that based on a very old version of VirtualDub?), but in the 'real' VirtualDub, you activate the feature for a given filter by clicking on 'Blend' in the Video Filters dialog. To select the frames for which you want to apply the filter, go to View->Curve Editor - set the opacity to 100% where you want the filter and 0% elsewhere.
In the Help, it is described in the section Processing->Video Filters->Filter Curves.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Problem Splitting MPEG and rejoining with mplex
By jon111 in forum Authoring (DVD)Replies: 6Last Post: 3rd Mar 2011, 21:13 -
Cropping and combining video segments
By hockeygt975 in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2008, 15:10 -
Errors When Joining Video Segments
By nona in forum EditingReplies: 9Last Post: 15th Feb 2008, 21:40 -
splitting/rejoining software
By motleycool in forum EditingReplies: 2Last Post: 14th Dec 2007, 17:49
