I read the posts of the Doom9 forum link I got from SupaCoopa:
http://rilanparty.com/vbb/showthread.php?s=&threadid=5905
I do have a question about encoding an anamorphic SVCD.
SVCD FREAK explains in his post that there is a difference in the SVCD quality depending on the source having aspect ratio 1.85:1 or 2.35:1.
I don't really agree to this:
- In both cases the resulting anamorphic SVCD contains no black bars right? Otherwise it would not be anamorphic, right?
- No matter what the aspect ratio of the DVD is, the resulting SVCD will always contain full-screen movie data of 480x576 resolution. A movie that will be stretched horizontally on a 16:9 TV screen.
- I agree that the way the data is stored on the DVD is different but no matter what source, 1.85:1 or 2.35:1, there are always 480x576 (=276480) pixels movie data that need to be encoded to SVCD to obtain an anamorphic SVCD. So you always have to use the same "high" bitrate.
This makes sense right?
Any thoughts/comments on this?
Shimrod.
no, anything higher than 1.85 has black bars so that it fits on a 16:9 screen. so u can get away with a slightly lower bitrate because the black bars compress better. but i usually use the same bitrate anyway, for better quality.
Why wasn't anamorphic widescreen mandated by the dvd specs from the start?
By yoda313 in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2010, 19:50 -
Anamorphic widescreen with TMPGenc Author Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2010, 02:26 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 11:41 -
Anamorphic DVD from Widescreen h.264 Video
By trueg in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 16th Sep 2008, 10:47 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
