I thought that it was working, but I'm now experiencing audio sync issues with vdub. The audio is always delayed relative to the video. I've tried various combinations under the "Capture Timing Options" to no avail. This clip that I'm trying to capture is at the very start of a vhs tape, so I am starting the capture function before hitting play on the vcr. I even tried playing the clip first, hitting capture and then using the jog shuttle to back up, but that gives the same delay as well.
Does anyone have proven capture settings for vdub that will solve the problem, or is there another more reliable capture app for avi ?
BTW : My system is Vista, vdub 1.9.11![]()
Results 1 to 9 of 9
Is the audio coming from your capture card or sound card? There can sometimes be timing issues if the audio isn't processed by the capture card first, but is sent directly to the audio-in port from the VCR.
Also, if your re-encoding the captured video afterwards in VirtualDub, you can also also adjust the timing then from the audio interleaving window. -
Need a little more information, the problem may not be with vdub at all. What type of capture device are you using USB, firewire, capture card. make and model of device could be helpful as well.
I remember some of the K-World external devices having a problem syncing audio you were better off to capture the audio through your computers sound card.Last edited by dragonkeeper; 29th Oct 2011 at 16:50.
Murphy's law taught me everything I know. -
I am capturing using an ATI Tv Wonder 600 usb. This has worked well for me in the past with no audio sync issues. Both audio and video are going through the ATI device.
There is a very simple program, STOIK, here in the tools section. Perhaps worth a try.
Hasn't been updated for a while, but works well with my Avermedia PCI-e card. -
Is this happening only with the one tape you mention, or is it happening all the time? Also, restore your capture timing to the defaults (they are shown in VDub Help) and start capture with the "F6" key, not with "F5". Since fiddling with timing settings doesn't help, go back to the settings that always worked in the past; if these settings and hardware are what you've always used successfully with other tapes and sources, and nothing else has changed, then the problem is the tape - not the setup or hardware.
If the clip on the tape starts immediately and there's no lead-in time from the tape itself, there are frame timing problems on that tape. You will have to re-sync audio later, or use an external frame-level TBC.Last edited by sanlyn; 21st Mar 2014 at 06:20.
Uh oh. Put me back on the short bus. The problem wound up being the settings on my ACE converter in between the vcr and proc amp. The section for standards was set to PAL, and 50 Hz. Although the audio was in perfect sync in the virtualdub screen during capture, the settings were confusing the ATI and/or virtualdub.
Order has been restored. Thanks to all !!
Ah, ye old PISB-KAC from my programming days ("Problem Is Between Keyboard And Chair"). Been there many times
TV Capture with EasyCAP and VirtualDub Audio out of sync
By olobay in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 18:19 -
Samsung BD-C5500 Audio Sync issues with AVI etc
By dukestravels07 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Sep 2010, 15:38 -
Audio Sync Issues From AVI
By tyders in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2009, 09:36 -
Virtualdub causes audio sync issues after cutting/saving
By Mr_Lyle in forum EditingReplies: 1Last Post: 23rd Apr 2008, 15:55 -
Weird avi audio sync issues
By afied080 in forum Newbie / General discussionsReplies: 8Last Post: 25th Oct 2007, 17:04
