Is there a way to edit(change) the chapter points in Ifoedit?
Not without reauthoring.
That is, demux (PGCDemux), edit the Celltimes.txt to whereever you want to set the chapter points (understanding that they may be changed a bit during authoring to reflect the fact that they have to be set on I-Frames), remux (although Muxman is better than IFOEdit for authoring).
You can actually set new chapter points in VobBlanker, but I'd still go the way I described. -
Just use a text file such as this and insert it into the sub section of ifoedit,you can also edit the time codes in the text before you use it.
Ya,your right,i just did a quick test but it didnt author with chapters in a full author,here's the right text.
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 08:52 -
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 09:21 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
