Hi Guys,
I recently purchased a Blu-ray re-writer and I'm looking to make some Blu-ray disks using tsMuxer but I'm having a problem with some of the files.
I had a friend send me some football games in HD (mpeg-2,ts container) and I tried muxing them to Blu-ray but the resulting file ends up out of sync.It'll start out ok but gradually it gets worse.
The funny thing is on some of the files I've had no sync issues at all but on others I've had nothing but problems.
Does anyone no why this is happening or can anyone recommend another program that will work for what I'm looking to do?
I'm kind of a noob at this so any help would be greatly appreciated.
Thanks.![]()
Thanks for the reply,here's the info on one of the problem files:
General
Complete name : C:\Users\pcw2936\Desktop\2010 NFC WC - #4 vs #5\2010 NFC WC - Saints @ Seahawks.ts
Format : MPEG-TS
File size : 16.7 GiB
Duration : 2h 45mn
Overall bit rate : 14.5 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Codec ID : 2
Duration : 2h 45mn
Bit rate mode : Variable
Bit rate : 13.4 Mbps
Maximum bit rate : 65.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.215
Stream size : 15.4 GiB (92%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2h 45mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 454 MiB (3%)
Language : English
Text #1
ID : 2048 (0x800)-608-1
Menu ID : 1 (0x1)
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Duration : 2h 45mn
Stream size : 0.00 Byte (0%)
Text #2
ID : 2048 (0x800)-1
Menu ID : 1 (0x1)
Format : EIA-708
Duration : 2h 45mn
Problem is usually errors in the files that cause the sync problem,hard to fix cause it takes a lot of editing.
tsMuxer Help Please!!!
By zzNyQuilzz in forum Video ConversionReplies: 3Last Post: 26th Sep 2011, 09:17 -
Need help with tsMuxer PLEASE
By elsey1983 in forum Video ConversionReplies: 0Last Post: 14th Dec 2010, 12:43 -
TsMuxeR
By dadi in forum SubtitleReplies: 3Last Post: 11th Aug 2009, 17:39 -
tsmuxer help
By magmo in forum Blu-ray RippingReplies: 1Last Post: 20th Jul 2009, 05:35 -
tsmuxer
By rozeb005 in forum Authoring (Blu-ray)Replies: 6Last Post: 16th Mar 2009, 10:18
