I rip a dvd but do not want to encode it. My Samssung tv will play vob files off usb hardrive. The picture when playing on tv is in wide screen but is small picture with black all around it. Do i need to encode it to have a picture just like i was playing the actual DVD?
I just wanted to copy some of my dvds to usb drive without encoding to something else
	You can try "remux" it to mpg with vob2mpg or to an mkv with mkvtoolnix. It might work better than the vob container. No reconversion.
	Well vob2mpg and mkvtoolnix worked but not what i was looking for. It did'nt stretch the picture out to fill the tv screen. What i'm looking for is to copy DVD movies to usb drive without taking the time to reencode and have just the movie play back on tv just like watching it from DVD player. I'm assuming that the ifo file on dvd tells the dvd player what the output would be- like 16.9 or full screen. I guess i will probally have to reencode and loose a little quality
	If your TV has a ZOOM button ( may be other name) on your remount, just use that to stretch the picture. Look in your TV manual. My TV works like that.
	Congratulations. I know you don't want to hear this but you just learned a hard lesson that TVs are not "plays everything perfectly" playback devices and they all have limitations, which you have hit.
 Please explain better on what your intentions are. You talk about a "USB drive". Are you trying to rip a bunch of DVDs to a large external hard drive so you can play them back from that? If so you'd be better served to just buy a Western Digital or similar streaming media player and give up on the idea of using the TV to play files. If I could bitch slap the entire TV industry for even allowing direct file playback I would do it because all it did was create the false impression that TVs are "plays everything" devices now.
  Playing subtitles off VOB file in Media Player ClassicBy aduh11 in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2009, 15:44
  Burnt DVD with vob problem (not playing on computer)By lamaddvd in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2009, 15:28
  Problem with Audio when playing VOB dvd filesBy rbrown871 in forum AudioReplies: 9Last Post: 8th Dec 2008, 10:36
  Problems when playing DVD VOB filesBy rbrown871 in forum Software PlayingReplies: 2Last Post: 25th Nov 2008, 21:10
  Which VOB file is currently playing?By CBNY in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2008, 07:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
