  1. Hi,
    I wanted to know if SDI, BNC and Composite cables are all the same (maybe Coax) or not only the connectors but also the cable are different??
    All different, but also the same.
    Depends on what part of the cable to which you prefer. (Gauge, for example.)
  3. BNC is a connector, like RCA is a connector
    SDI is a (75ohm) cable with a BNC connector (digital)
    Composite is sometimes rated to 75ohm and almost always has a RCA connector (analog)
    Component being almost the same as composite (75ohm, analog, RCA or BNC)
    Originally Posted by jagabo
