  1. Hi, someone in another thread recommended DVDFab as a good ripping tool to use, as opposed to the older DVDShrink or DVD Decrypter, so I have downloaded the trial version onto two different laptops, and so far like it a lot.
    Question, though: On one laptop it assembles all the ripped files into one single file, while the other laptop divides it into four different files I then have to join together.
    Is there a simple setting somewhere in DVDFab that I can change so it always assembles the ripped files into a single file after ripping? I'm a bit of a novice, and don't know where to look.
    Thank You!
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Are you actually just "ripping" them or converting them to another format ?
    What format are the "file(s)" in on your pc after "ripping" them ?
    Because if you are just "ripping" the dvd's you will always end up with a VIDEO_TS folder with multiple VOB's, IFO's & BUP's regardless of what pc they are ripped on.
    Exactly like the original dvd.
    https://www.videohelp.com/dvd#struct
    Sep 2011
    I have been using Dvdfab for years and never had that problem, Try uninstalling Fab and reinstall.
  4. Noahtuck, it looks like DVDFab must be both ripping and converting the files. Instead of a bunch of VOB's, I'm ending with a single MPG. Does that make sense?
    But again, why is one version doing it and the other isn't? Could it be different OS's? One is in a Vista laptop, the other is running on XP.
  5. Member dragonkeeper's Avatar
    Jul 2003
    Sounds like you may have inadvertently chose to convert the movie on the other laptop. Did you happen to disable the selection menu that appears at start-up, if so it may by defaulting to the last choice you made.
    This is only thing that comes to mind i have used DVDFab for years and have never heard of a problem like this.
    Murphy's law taught me everything I know.
  6. Dragon, this is not a problem, it is actually an advantage. I would PREFER to have it all in one chuck, not in separate VOB's. No, I did not intentionally change the settings or menu on either install, it just came out that way.
    It would save me a lot of time if I could get the second laptop to do this as well, since I am approaching deadline and could use both laptops going at it.
    Thanks, Dragon, and thanks in advance to anyone else who chimes in here.
    Best,
    CharmedLife417
  7. Member dragonkeeper's Avatar
    Jul 2003
    Sorry I guess i didn't fully read your post. Try selecting movie only that's the only thing i can come up with also chack the structure of the DVD where you say all the files were joined, it may be that the movie was in one vob (i have seen this many times).
    Nov 2011
    This is probably a little late....
    To Rip and Convert with DVDFab, "all in one chuck", you click on "DVD Ripper", found on the list of modes or "options" on the left side of the main program window. You can then choose from 20 or so different output formats.
    I'm amazed that two guys responded who have been "using DVDFab for years", and neither one could just tell you which mode to pick.
    Selecting "Movie Only" isn't gonna do anything. And what difference does it make how many VOB's the disc has on it ? He's winding up with one file, yes, but it's an .mpg.
