I am trying to create a bdmv to burn to a blu ray disk using an mkv file as the input. I want to add a menu and transcode the file to make it compliant but every time I try, multiAVCHD fails after the transcode process, which according to the log goes fine. The multiAVCHD log shows the following,
[10:24:51] Initialising...
[10:24:52] Checking for new version...
[10:24:52] You have the latest build.
[10:24:52] Consistency check finished!
[10:24:52] Initialization finished. multiAVCHD is ready!
[10:24:52] 2 years and 306 days since multiAVCHD was published.
[10:24:52] 468 people supported it with donations
[10:24:52] and you are the 3474651 one to launch the program...
[10:24:52] Support multiAVCHD to extend its features and keep it going!
[10:24:52] multiAVCHD.dat version: [04010767]
[10:25:01] [TRANSCODE]: Title#01 10250 kbps, 1920x800 -> 1920x1080
[10:35:13] Checking for available space and drive types (FAT32/NTFS)...
[10:35:18] Destination [C:]: NTFS, 151721.01 MiB (148.165 GiB) free space
[10:35:18] Temp folder [C:]: NTFS, 151720.71 MiB (148.165 GiB) free space
[10:35:18] Log started for multiAVCHD v4.1 (build 770)
[10:35:18] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
[10:35:18] Processing one title...
[10:35:20] Processing (D:\************\*******\**********-1080p.mkv)...
[10:35:20] This title is marked for reencoding / uncropping...
[10:35:20] Encoding process may take 10 min to 10 hours, so be patient...
[10:35:20] *** Initiating video encoding:
[10:35:20] *** Original : 1920x800
[10:35:20] *** Crop : 0
[10:35:20] *** Resize : 1920x800 (No change)
[10:35:20] *** Uncrop to : 1920x1080
[10:35:20] *** Sharpen : 0
[10:35:20] *** Bitrate : 21291 kbps
[10:35:20] *** Frame rate: Original (23.976)
[10:35:20] *** Level : 4
[10:35:20] *** Quality : One pass (insane)
[10:35:20] *** SAR : 1:1
[10:35:20] *** DAR : 1920x1080
[10:35:20] *** Profile : Blu-ray
[10:35:20] *** Encoding : One pass - content: [02:10:19]
[10:35:20] *** Encoding : x264 options: --preset ultrafast -B 21291 -I 24 --level 4 -i 12 -b 3 -m 0 -r 4 --ipratio 1.4 --vbv-bufsize 25000 --vbv-maxrate 20000 --qcomp 0.5 --threads auto --thread-input --aud --nal-hrd vbr --sar 1:1 --me dia --b-pyramid strict --slices 0 --weightp 0 --rc-lookahead 0 -o "D:\************\*******\**********-1080p.mkv[1920x1080-23.976].264" "C:\multiAVCHD\_TEMP\multiTEMP-20111028\20111028-103520-uncrop-running.avs"
[12:07:43] *** Speed : 33.82 fps (elapsed: 01:32:22 - Realtime x 1.41)
[12:07:43] *** Transcoding successful!
[12:07:44] Detected frame reference count: 3 (max:4).
[12:07:44] Detected video: ID#0:V_MPEG4/ISO/AVC 1920x1080, fps=23.976, ref=3
[12:07:44] Detected audio: ID#2:A_DTS (48000Hz 24bit 6ch 1472kbps) Language: und
[12:07:44] Added audio: A_DTS, "D:\************\*******\**********-1080p.mkv", track=2, lang=und, timeshift=0ms
[12:07:44] M2TS stream split set at 23000MiB...
[12:07:44] Creating clip and playlist info (tsMuxeR)...
tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: Main@4.0 Resolution: 1920:1080p Frame rate: 23.9761
Change H264 level from 4 to 4.1
H.264 manual setted fps not equal stream fps. Change H.264 fps from 23.9761 to 23.976
tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --split-size=23000MiB --vbv-len=500
V_MPEG4/ISO/AVC, "D:\************\*******\**********-1080p.mkv[1920x1080-23.976].264", lang=eng, level=4.1, fps=23.976
[12:19:31] Important files missing (clpi/mpls/m2ts)...
[12:19:31] Possible tsMuxeR failure to process your input file (D:\************\*******\**********-1080p.mkv).
[12:19:31] M2TS (media) file count: 0
[12:19:31] CLPI (clipinfo) file count: 0
[12:19:31] MPLS (playlist) file count: 0
[12:19:31] Skipping to next...
[12:19:31] ERROR: Compilation does not contain any HD-DVD/AVCHD/Blu-ray titles!
[12:19:31] Preparing menu pages...
[12:19:31] Setting main menu for 0 titles...
[12:19:31] Selected TV system: [PAL]
[12:19:31] Setting Blu-ray format...
I have tried to run the same mkv file through gdsmux.exe but once this mkv goes through multiAVCHD I end up with a film with a serious audio sync issue. The following is the mediainfo data on the original mkv file,
General
Unique ID : 224235653900517329532292602176476750747 (0xA8B2374EB35AA251B0CED97D11D7239B)
Complete name : D:\************\*******\**********-1080p.mkv
Format : Matroska
File size : 10.9 GiB
Duration : 2h 10mn
Overall bit rate : 12.0 Mbps
Encoded date : UTC 2011-10-26 11:10:23
Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 10mn
Bit rate : 10.5 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.285
Stream size : 9.34 GiB (85%)
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=10491 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 10mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.38 GiB (13%)
Language : English
I don't seem to be able to complete this project at all and have not had problems with other mkv files. Anyone got any ideas on a possible cause for the tsmuxer failure?
Cheers
Tony
Results 1 to 9 of 9
Just like back in the early Divx days when dumbass people thought that having GMC of 3 was just fantastic, from what I've read it seems that a growing number of dumbasses are now convinced that Header Stripping if just fantastic too. It's NOT. But then again you didn't pay for the video so it's like you've got any room to complain. So my guess is that header stripping is screwing you over. There is some way to fix it but I don't remember what it is. You might search the forums for "header stripping" or maybe someone will post later on what to do.
here is the procedure to clear header striping. (Required tools:mkvmerg)
from command line:
mkvmerge -o myVideo.mkv --compression -1:none myVideo.mkv
From gui:
Add file--make sure all tracks u want are checked-->in the "extra options" tab you must set compression to none -->click "Start Muxing"Murphy's law taught me everything I know. -
So I'm having what appears to be the same problem as the OP. I have some episodes of a show I recorded from an InfiniTV card which started out as MPEG2 .wtv files with AC3 384kbps audio. I edited out the commercials with VideoReDo and saved them as .m2ts files. I then used VidCoder to render these at CRF 20, decomb, detelecine to give me some nice 1080p 23.976 fps MKV files and transfered to my server for backup. I also loaded these MKVs into multiAVCHD to make a bluray backup and the resulting .iso file when viewed with TMT5 has major audio synch issues. I figured maybe TMT was being goofy so I burned the iso to a BDR with ImgBurn and popped it in my PS3.... same synch problem. I tried the mkvmerge trick to save the header but after going through the same process up to the .iso image, I still had the synch problem. Any ideas? Thanks in advance!
Help! -
cjbrown80 - Probably should have just made a new thread for this. It's really best to avoid thread hijacking although I will grant you that in this case your post is arguably somewhat related to the original topic. Anyway...
You need to determine where the sync issues begin. Is your edited video in sync after VideoReDo finishes editing it? VideoReDo has intelligent ways to deal with dropped and bad packets from TV recordings so what you get after VideoReDo finishes SHOULD be in sync. If not, you might try VideoReDo's stream fixer under the Tools section of the GUI. If it goes out of sync after VidCoder handles it, then you have at least determined where the problem is. Do note that some TV channels do really crazy things to their signals. In the USA, CBS has probably the most screwed up broadcasts of anybody. They've been known to mix framerates and at least where I live, dropped packets are common. I gave up trying to record anything to my PC from CBS long ago, but fortunately I don't watch many CBS shows so it's not a problem for me to just not record them. -
Jman- Apologies on the hijack, it seemed like my trouble pertained enough to the OP that it would be better here than a new thread, sorry.
The MKVs from VidCoder are perfectly fine viewed through MPC-HCx64 or WMP/WMC. I'm assuming the sync problem occurs during the muxing process multiAVCHD is performing to create its .m2ts files. Does that sound like the "header stripping" issues others have had?
Thanks for your input!Help! -
Dangit! I think I figured it out. My VidCoder preset somehow slipped over to "same as source" for the frame rate setting (which I believe will result in a variable rate). Even though it's reported as 23.976, when I load the MKV file into tsMuxer, it shows the frame rate as 90,000 (obviously not what it should report). I manually set it to 23.976 and I'm running an encode of one of the episodes right now. I'll report back if this solves the problem or not.
Help! -
I have m2ts files that I edited the commercials out with TSSniper. They play fine in media player and media player classic. However after I use MultiACHD and burn the bluray disc the audio is out of sync. So your culprit may be MultiAVCHD.
I tried using DVDArchitect Studio 5 and it makes the files play too fast and with no sound. I figured mayber DVDArchitect studio doesn't properly support .m2ts files. So I tried capturing in .mp4. The files are MUCH smaller and don't appear to play smoothly.
It's been a pain in the azz to get my shows to a bluray with menus.
Btw I'm capturing with a Hauppauge Collossus card with Arcsoft showbiz.
Anyone have any success getting the files onto a bluray with menus and playing properly?
MultiAVCHD Problems
By Startropic1 in forum Authoring (DVD)Replies: 6Last Post: 16th Jan 2012, 18:55 -
Does multiavchd or tsmuxer support .tp files as input sources?
By yoda313 in forum Video ConversionReplies: 8Last Post: 8th May 2010, 08:08 -
Problems with MultiAVCHD 3 mkv movies to DB
By Dragonsf in forum Authoring (Blu-ray)Replies: 6Last Post: 27th Jun 2009, 23:41 -
Problems with subtitles using tsMuxer
By cruck in forum Authoring (Blu-ray)Replies: 3Last Post: 7th May 2009, 02:11 -
Problems with TsMuxer
By fazza8 in forum Authoring (Blu-ray)Replies: 8Last Post: 11th Jan 2009, 15:33
