Am I completely blind or is there no way to output both m2v and ac3 with a single click of the Render As dialog? Can someone point me in the right direction? I can't be the only one that wants to use ac3 sound encoding with mpeg2 video, yet the only option I can find is to output mpeg with mpa audio. Can anyone help me?
- Smells_Like_Feet
correct mpeg-2 encoders can only make m2v video and mpa audio. make your ac-3 audio with the dolby digital ac-3 encoder. authoring programs want separate streams anyway.
I kind of figured that this was the case, but what doesn't make sense to me is that mpa is not a valid DVD audio encoding. My understanding is that DVD requires either PCM or AC3 audio and if I choose to render to elementary streams why not allow the encoder to render the audio (to AC3) immediately following the m2v render. I mean Vegas has templates that are marked for DVD Architect, but does not allow that template to make use of the Dolby Digital encoder for an elementary stream output... It's just a pet-peeve of mine with respect to Vegas.
- Smells_Like_Feet -
Yes, it is. For PAL DVD.
Your understanding is wrong.My understanding is that DVD requires either PCM or AC3 audio
Who cares? Just do as aedipuss suggests....and if I choose to render to elementary streams why not allow the encoder to render the audio (to AC3) immediately following the m2v render.
Sony Vegas Pro 11 Question: Video in Preview and Finished Render "Choppy"?
By MoreThanLuck in forum EditingReplies: 7Last Post: 31st Dec 2011, 21:17 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
How to disable MPC "could not render some of the pins in the graph" warnng?
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2011, 23:50 -
HD video from laptop to HDTV - "Clone" or "Single?
By mr-scarface in forum Software PlayingReplies: 1Last Post: 1st Jun 2009, 23:06 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
