This is my situation...My laptop died recently and it's far too expensive to fix but I thought maybe I could use the serial number that came with it to install Win 7 onto another desktop. Can I use my Win 7 HP 64 serial number on a new pc build? I do have a purchased Win7 HP 64 retail disc with a key but it's not what came with the laptop. So basically I have 1 disc with a key and the dead laptop with another key that came with it. Can I install Win7 HP 64 onto 2 different pc's since I have 2 keys or no? I'm not quite sure how this works so I thought I'd ask first.
thanks
mt
Results 1 to 9 of 9
Probably not. OEM licenses are usually locked to the OEM BIOS. It might work if the new motherboard is from the same OEM.
Does the authorization code have "OEM" in it? If not, it might work and is worth a shot. I have recently used a number of old Dell auth codes for XP, their install disks are keyed to a Dell mobo but at least some of the auth codes are not.
it says "windows 7 home premium oa"....from reading online i don't get to install it on anything but this dead laptop...whatta jip lol
oh well...thanks for your input guys...it put me in the right direction
Try it, what do you have to loose?
If I'd known I was going to live this long, I'd have taken better care of myself. -
any thing hp is oem and may work fine with any hp computer (bios) that support win7/vista.
try it out
best of luck -
I can tell you that I had a dead asus all in one that I parted out but I kept the coa. I installed it on another computer and it works great. I had to call microsoft through there automatic register system but it authorized it immediately. Hope that helps.
more than 70 ways to bypass Win 7 activation
By deadrats in forum ComputerReplies: 13Last Post: 22nd Feb 2010, 08:55 -
Registration key and activation
By philparis in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2009, 17:56 -
Win XP activation code
By CSULB71 in forum ComputerReplies: 19Last Post: 18th Apr 2008, 19:49 -
Lost Activation Key
By scully_uk_98 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Feb 2008, 11:53 -
New Laptop V Key Keeps Falling Off
By Garibaldi in forum ComputerReplies: 21Last Post: 13th Jun 2007, 23:45
