Hello Guys
I had DVD Flick for about 2 years, never had
any problem recording any DVD, recently I
started to have this problem: when the program
starts inserting subtitles I receive this
message "bmp2png.exe is currently used by
another program", that's the file located in
the DVD Flick directory, and nothing is
recorded after this and the encoding process
can stay forever!
Can I get some help please!![]()
I found out now is that if I try to insert the subtitle manually it gives me this message "the subtitle has overlapping timestamps" and that dvd flick will try to fix it.
I guess this is where the problem starts from, i've uninstalled and reinstalled dvd flick, vobsub and k-lite codec but still get the same message about overlapping even that subtitle is working perfect when i display it on media player classic! -
I think you can try fix overlapping subs with subtitle edit or subtitle workshop.
Or else can you try other easy all-in-one converters like avstodvd or freemake video converter. -
Hello and thx very much for your help, I tried the DVD programs but nothing is great like DVD Flick, there was an overlapping problems with the subtitles so Subtitle Edit solved it, I've recorded 3 DVDs so far with no problem, hope it goes on like this, thx again for help.
DVD FLICK -always same error
By phonkilla in forum Authoring (DVD)Replies: 8Last Post: 16th Jun 2013, 10:24 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
DVD Flick gives me an error
By shashgo in forum Authoring (DVD)Replies: 11Last Post: 29th Jan 2009, 09:11 -
DVD Flick Error
By Robert Simandl in forum Video ConversionReplies: 1Last Post: 25th Sep 2008, 22:34 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 08:20
