  1. .mts File Hater JohnnyGalaga's Avatar
    Jan 2011
    USA
    It happens with either .mp4 or .mt2s high-definition videos on both Media Player Classic or VLC. These are 1080 30p or 60i files saved an the C:\ drive (an HDD) that just stop playing after a few minutes. Is this a hardware problem? How do I troubleshoot this? It doesn't happen every time, but prolly like 1/3 of the time, even with the computer resolution only set to 1084 x 768.
    The computer doesn't crash, just the video playback. It gets to a point and the frame just stops and shows a still image but the audio keeps going. If I then exit out of the Media Player Classic or VLC player and wait about 3-4 minutes, it lets me start the video over again.
    Any ideas? Thanks.
    Intel i7-950 ASUS GeForce GTX460 1GB 12GB G.Skill DDR3 1600 MHz OCZ Vertex 2 60GB SSD WD Caviar Black 1TB 7200 RPM 64MB Cache
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Spare us trying to figure your computer (yeah i7), just explain the source format.
    http://www.kiva.org/about
  3. .mts File Hater JohnnyGalaga's Avatar
    Jan 2011
    USA
    These are .mts files from a camcorder that I edited in Sony Vegas Platinum 10 and saved as either .mp4 or .mt2s files.
  4. Member edDV's Avatar
    Mar 2004
    OK on my todo list.
    What Camcorder?
    These days I find I'm defending/promoting history over at Linkedin. History is a battle.
  5. .mts File Hater JohnnyGalaga's Avatar
    Jan 2011
    USA
    It's a Canon HF21. This only started happening about 1 - 2 months ago. Before then everything was fine.
    Oct 2005
    666th portal
    kinda long to wait to try and figure out. do you recall what you changed just before the problem? software updates? codec packs? video driver? does the video card pass a stress test?
