Anyone know of a good 19inch LCD PC Monitor, non-widescreen, that has one or more of the following connectors:
YPbPr analog component video
S-video
DVI-I dual link
If so, please advise brand name and model number, so I can track one down!
Results 1 to 15 of 15
Its no longer made but the Samsung Syncmaster 930MP meets your requirements. 1280x1024 native resolution, has built in composite, s-video, YPbPr component, DVI-D (with HDCP), VGA , and even SCART RGB (15.75khz) inputs. The SD inputs even accept PAL, NTSC, and SECAM video.
http://www.kiva.org/about -
So far as I know (not very far), a regular LCD TV set will not sub for a computer monitor. Anyway, already have LCD TV. If you're asking about resolution, '1280x720' is about best I need, and considering I will not touch HDCP crapola, I will likely get by with less resolution.
I'd bet your 1280x720 LCD-TV is really 1366x768.
A 1920x1080 LCD-TV makes a good computer monitor but adds analog inputs and video processors for deinterlace, inverse telecine and higher quality scaling than a computer monitor.
Computer monitors are designed only for display card input.Recommends: Kiva.org - Loans that change lives.
Yep...so it should then follow that I will not be playing "protected HD media". Had considered having HDCP then using 'strippers', etc., but decided on just not fooling with it from the get-go. Will excise DRM, COPP, etc., from XP Pro, Windows 2000, and Windows 98 which closes the door on HDCP...hence no need for HDMI, DVI-D, and so forth.
930p
Response Time 25 msRecommends: Kiva.org - Loans that change lives.
The Samsung 930P is a six year old LCD. Letterboxing a 1280x720 image on the 1280x1024 display will leave you with a ~17" picture. It appears to have a 6 bit (per primary) LCD panel too. And it has HDCP on the DVI port. Total crap by todays standards. The best price I saw via a quick Google search was $300 for a refurb. About $1000 new!
It was an early attempt at a combo computer monitor/HDTV and probably the only one not wide screen.
Samsung has had a full line of 16:9/16:10 computer monitors with S-Video, component, VGA, DVI-D and HDMI inputs. Also an ATSC or DVB tuner.
I've got a 2333HD that has analog component, VGA, DVI-D and 2x HDMI inputs. There were several other models.
The latest models have dropped the analog inputs other than VGA but still include an HD tuner..
http://www.samsung.com/us/article/hdtv-monitor-101Recommends: Kiva.org - Loans that change lives.
Recommendations Please, Blu-ray Player with USB HDD support
By Hollywood_12 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Mar 2012, 16:53 -
Video Editing Monitor Recommendations
By VideoTechMan in forum ComputerReplies: 41Last Post: 9th Oct 2011, 16:06 -
Need some guidenace or recommendations
By TwoMutts in forum Media Center PC / MediaCentersReplies: 2Last Post: 8th Feb 2010, 18:42 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 07:43 -
I am looking for recommendations
By Tidy in forum DVD & Blu-ray WritersReplies: 5Last Post: 8th Jan 2008, 12:48
