I have a 16:9 video I've been trying to convert to x264 avi using 2-pass mode in VirtualDub. When I check the resulting file with MediaInfo I don't see a 16:9 notice and when uploaded to YouTube, it isn't recognized as 16:9.
Can anyone clue me in to what needs to be done to end up with 16:9?
Maybe mpeg4modifier can adjust the avi headers to 16:9. Or it might be mpeg4 asp/divx/xvid only.
Or resize to a 16:9 resolution/video frame size with virtualdub. -
x264 is a square pixel format. so whatever size you make it, is how it's shown. 1280x720 is an example of a 16x9 size.
no it supports non square pixels, but for youtube resizing uisng square pixels is probably better
if you wanted to use non square pixels , you use --sar x:y , where x:y is the width:height of pixels similar to Pixel Aspect Ratio. In MPEG4 terminology it's called Sample Aspect Ratio or SAR
you would use 32:27 for 720x480 full frame 16:9 , or 40:33 if you were basing your calculations on 704 pixel size or SD blu-ray
16/9 = 720/480 x 32/27
x264 codec decoding limitations
By Medieval1233 in forum Portable VideoReplies: 2Last Post: 30th Dec 2011, 18:54 -
I want use x264 codec in virtualdub but i can't
By Hugo12317 in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 14:41 -
I can't figure out how to use the h.264 (x264) codec!
By Tahlos in forum Newbie / General discussionsReplies: 9Last Post: 15th Jun 2010, 19:34 -
VirtualDub doesn't see x264 codec.
By olegk in forum Video ConversionReplies: 7Last Post: 9th Jun 2010, 03:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40
