Results 1 to 10 of 10
  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I've been using AviDemux forever but don't really know all that much about the intricate workings of it.....BUT my questions are simple.
    1) Does AviDemux come with x264 encoding abilities. I know my version has it but mine is old and don't know if I'm looking at that VFW codec I installed(for VirtualDub) or a built-in one.
    2) How can someone encode a video(with AviDemux) and copy exactly what HandBrake does with it's Apple iPhone & iPod Touch preset(no customizing).
    A friend of mine uses Handbrake(on my recommendation) to encode files for her iPhone....but she would now like the ability to edit out dead video to make the videos more appealing while watching(I doubt her main concern is end-result file size) before creating the iPhone video.
    I also see there is no .m4v-type of output option in AviDemux....
    Any easy way to describe this process TO A NEWBIE would be greatly appreciated.....if it is possible at all. I also just use HandBrake's presets for my iPod touch as well.
    1. Yes it has built in x264(mpeg4 avc).
    2. avidemux has also iphone and ipod profiles, under Auto->Apple.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Is it supposed to set the video and audio compression for you? It's doing nothing for me....by just using the presets I'm getting uncompressed video with PCM audio(same as my source).
    Yes, it changes the video and audio codecs. Did you load the video file first?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Or maybe is freemake video converter easier to use. It can also cut out parts similar as avidemux, click on the scissor and set start and stop, cut.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    OK....I just re-did it making sure to open the video file, then applied the preset and the compressions changed.
    THANK YOU Baldrick.
    I cut all the time with AviDemux so I think it will be easier to explain the procedure to her with something I'm familiar with. I'll keep the other program in mind though.
  7. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    The great news though, is the i - Phone/Pad/Pods only play the .MP4 extension.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    In the immortal words of Gene Wilder as Willy Wonka.... "WRONG!"
  9. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Love that Gene Wilder. Did you see "Silver Streak"? Great movie.
    Well, that's the only container I've been able to play without getting transcoded by iTunes. Maybe I'm doing something wrong.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Encode with Handbrake and transfer to the iPhone/iPod Tounch via CopyTrans.....can't beat it.
