Hi all just found this forum and it looks excellent but I have not been on many forums for computer help/advice. Hope someone can help? <?xml:namespace prefix = o ns = "urnchemas-microsoft-com
ffice
ffice" /><o
></o
<o></o
I have been trying to save data from my pc using Nero 6 and keep getting error messages saying: "non critical error" when trying to copy data. Does this mean it will burn my data but to DVD but may not be able to be read once it’s been burned, or will it just not burn all the data in the folder I am trying to burn form my HDD to DVD? It looks like it could be a filename that is too long but not sure now what is the limit of characters can be used in a file name. Any help would be greatly appreciated.
craigsb<o
></o
Moving you to our computer section.
Nero 6? It's very old....maybe try nero kwik burn, cdburnerxp, etc. -
Hi baldrick, Many Thanks for your prompt reply. I was going to upgrade my version but didn't think i had to as i thought it should still work ok, as i am using the same pc and DVD RW as before and didn't get these messages before?
My RW type is an NEC_DVR_RW ND-1300A and it is about 3 years old but i only use it for data back-up, and don't copy much else. wil look into updating when i've backed up my current data.
Regards
craigsb -
Which version of Windows are you using?
XP is the last MS OS that Nero 6 supports.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Fot it's intended purpse Nero is very bloated. There are many free apps that do a better job. Personaly i recommen Imgburn
Free Burning tools.Murphy's law taught me everything I know. -
Hi all, many thanks for all your great input, to answer some of your questions, the version of Win I am using is, XP Pro with service pack 3, also i have a 3.25 Ghz Pentium P4 Processor, and 512 Mb Memory i have had this configuration on my Pc for the last 3 years.
I didn't know you could get free burning software so will have a look at it, but as always a lot of people tend you use what they, have an know, but it looks like its time to either change or upgrade what i have. Has anyone got a good preference?
Thanks again for all your great input an await your ideas!
Regards
Craigsb
27-10-2011 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 10:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 02:11 -
Nero Replacement for Audio and Data burning
By mlong30 in forum AudioReplies: 6Last Post: 1st Jul 2008, 11:55 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
ffice
></o
<o
