    Mar 2008
    Hello,
    I noticed that some of the popular encoders, such as LamedropXP encode mp3's as joint stereo
    instead of pure stereo - even at the higher bitrates.
    I always believed JS was a compromise intended only for the lower bitrates, ie. 160 kbps and below.
    JS is preferred now?
  2. Member Cornucopia's Avatar
    Your impression agreed with mine, afa compromise @ lower bitrates. I'm guessing the programmer didn't know the differences and just guessed.
    Mar 2008
    I suppose anything is possible, perhaps somebody "in the know" could explain it, if there is actually
    a reason for it or whether it's a choice of convenience for the programmer.
    LAMEdropXP produces a very nice encode, vbr average ~200 kbps. Sounds great. I'd like to be able
    to compare it with the straight stereo, but this it's not possible with this tool (as far as I can see).
  4. Member olyteddy's Avatar
    Dec 2005
    Joint stereo encodes the stereo as a sum channel and a difference channel as I recall. For a given bitrate this allows more bits to the common sounds than to the difference channel, which should result in a better sounding encode. Regular stereo will have a lot of information repeated in both channels, thus 'wasting' bits. I use joint stereo for that reason. There is usually more in common between the channels than there is a difference. Some exceptions include 'Space Oddity' by David Bowie and 'Up From the Skies' by Hendrix. With the extreme panning and ping-ponging joint stereo probably uses more bits...
    Mar 2008
    I understand the theory re: the bitrate allocation, but somewhere in the back of my mind is this thought that
    JS was primarily intended for the lower bitrates. Perhaps I'm wrong. I wonder if LAME has been optimized
    so that JS is now the preferred mode?
  6. Member Cornucopia's Avatar
    No, you're not wrong, because at the higher bitrates (256, 320) the effect of JS bit allocation vs. plain Stereo allocation is extremely negligible (for lots of program material, but not all), unlike lower bitrates.
    BTW, if you ever work with binaural, Dolby Surround, or other material that makes much use of HRTF, Phase, or Delay, you will find that JS is actually detrimental to the sound quality.
    Mar 2008
    I made a similar post at Hydrogenaudio. The gist of the answer is that with recent LAME innovations,
    the encoder will pick, on a frame-by-frame basis, whether to use LR or MS stereo resulting in the best optimization
    at any given bitrate. Here's the thread:
    http://www.hydrogenaudio.org/forums/index.php?showtopic=91485
  8. Member Cornucopia's Avatar
    That was very helpful!
