Ok, so I authored a disc using DVD-lab pro 2. I have a chapter set in the range that is acceptable for a layer break. In dlp2 I go to the pre-mastering, set layer break, and it lets me set it on the chapter I want to.
Except that no other software seems to actually care about this.
I go into imgburn, and it wants to set it to a period of time past my chapter.
I tried setting the chapter in a different place, but no, imgburn still wants to go past that chapter now. and it's enough time past the chapter that it just screws up what I'm trying to do.
So, I decided to give dvd-architect a try, opened up the folder created from dvd lab pro 2, and it also will only let me do the layer break at the same point as imgburn.
So, what the heck is the point of dvd lab pro letting me select my chapter, but no other program caring about what I set? Why are these programs not going with my chapter point? What do I gotta do to get an accurate layer break on a dvd?
Nevermind, it seems to be another case of being tripped up by what uses drop frame and what doesn't, since no one can agree on how long a second, a universal unit of measurement, actually is.
Well, it seems to not matter what I do in dlp2 anyways. What was happening was I was setting my chapters based on time, since the chapter depends on the sound and not the visual, and dlp2 won't play the dolby digital soundtrack for me to zero in. I was using one method of time to zero in on my chapter, and entering it into dlp2 which was using the other type, so I ended up with a chapter being later than I really wanted it, due to the video world throwing science out the window and redefining a second to meet their needs :P
Anyways, I think I got it covered now that I have my clocks synchronized and can set my chapter properly.
Set Layer Break Manually
By koberulz in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2012, 12:19 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Layer Break Using ImgBurn Help
By Nitro89 in forum Authoring (DVD)Replies: 8Last Post: 30th May 2010, 09:01 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27
