Trying to convert a DVD movie to MKV. The movie has two AC3 2 -channel English soundtracks, one is stereo, and one is
mono. I just want the mono one. Is there an easy way to determine which one is which, as mediainfo doesn't seem
to distinguish that information. There are six audio tracks on the DVD, the first two are the 2-channel English soundtracks,
and the others are French, Spanish, and two commentary soundtracks. Thanks.
If BOTH streams use the 2.0 AC3 designator, the only way to tell is to open them up in an audio editor and listen and/or use a mono-compatibility plugin/channel strip, or use an app that can parse the channels and compare their decoded samples channel<-->channel.
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
how to: add 2 mono tracks = 2 channel wave?
By spiritgumm in forum AudioReplies: 4Last Post: 7th Sep 2007, 17:52 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 14:06
