    Aug 2005
    Europe
    I am using HandBrake for the first time and thinking if the standard options (constant quality: RF:20) will produce the best possible video output quality from a DVD to a mkv file using x264 video codec. Any advice?
  2. See here:
    https://trac.handbrake.fr/wiki/ConstantQuality
    To sum up: when converting from a DVD source, there is no reason to go above an RF of ~19, which is roughly equivalent to how heavily the DVD is compressed. If you do go higher, your output will be larger than your input!
    Oct 2005
    666th portal
    i'd recommend trying vidcoder(handbrake gui). adjust presets to your needs and save them.
    Aug 2005
    Europe
    I tried constant quality: RF:20 and the video quality was bad, then I changed to constant quality: RF:10 and the quality was much better, but the resulting file size was too big. In both cases I chose DTSPassthru to keep the original audio. I am now trying Avg Bitrate (kbps): 2500, but again I am not certain for the value.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    dts audio creates huge files by itself. try cq18 and converting dts to mp3 or aac.
