I'm about to shoot and edit a school play in HD. I will edit with premiere cs4. The question is what format to output to.
For distribution, I want to put the video clips on youtube, and also offer them for download so people not only can play them on their computers, but can also easily transfer them to their smart phones or tablets (iphone, ipad, android phones, android tablets, and optionally windows phones).
Is there one format I can encode to from premiere that satisfies all the above? If not, what are the minimum number of video formats I need to offer for each video clip?
Probably MP4 with h264 video and AAC audio. Video size/resolution around 960x540 or 640x360 (16:9 video).
Every time video is re-encoded, there is loss. You-tube re-encodes what you send them so it is better to use near the highest bit rate they will accept to get quality to the screen. The max bit rate you can use for Youtube depends on the length of the clip.
Same goes for re-encoding your file to various mobile devices. If you expect the user to do it themselves, you need to give them adequate bit rate in your distribution file.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Connecting HDMI (Android Devbice) output to an RGB/SCART TV socket
By excelis4 in forum ComputerReplies: 0Last Post: 20th Nov 2011, 03:03 -
MP4 Subtitle Question; Of Android(Tablet/Phone)/PS3/Iphone/Ipad Devices
By WearWolf in forum SubtitleReplies: 6Last Post: 31st Oct 2011, 02:54 -
Recommended FFmpeg command for converting videos to iPhone/Android
By wapatv in forum Video ConversionReplies: 0Last Post: 31st Mar 2011, 15:22 -
Streaming media to my android w/ TVersity... what format to use?
By LaxerFL in forum Video Streaming DownloadingReplies: 2Last Post: 12th Dec 2010, 12:27 -
run mp4 on iphone and android-smartphones???
By rashomon in forum Video ConversionReplies: 2Last Post: 1st Aug 2010, 08:31
