Hi all,
I have downloaded a movie file from the internet. Format of the file is AVI, with dimensions: 640x272, FPS: 23,97, NTSC Film
Within VirtualDub, I add subtitles to this file and frameserve it.
When I then use TMPGEnc to convert this file to MPEG, to put it on a
(S)VCD (PAL 16:9), the preview window looks OK: subtitles are readible and the aspect ratio of the film is in tact.
After burning the MPEG to a CD with NERO and play this CD in my stand-alone DVD player (PAL Europe), on the sides of the screen I have lost a part. This is particulary visible, as the first few letters of the subtitle (left aligned) are lost. I have tried about any parameter setting in both VDub and TMPGEnc, but can't figure out the right combination![]()
Can anyone help me out and provide me with the correct settings to use in both VirtualDub and TMPGEnc to encode this 640x272 NTSC Film with subtitles to (S)VCD format PAL 16:9. Of course, I do want to keep the aspect ratio.
Thanks in advance,
Klara
I have tried that, but still can't figure out the right combination of settings. Very frustrating...
I can hardly imagine that this is such a hassle, but then again, I still haven't got it working.
So if any one of you guru's out there can hook me up with the settings to use, I'd appreciate it.
Klara
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 16:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 12:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 14:21 -
FPS..NTSC & PAL Standard Cinema Film/Digital
By flamingo in forum TestReplies: 0Last Post: 9th Nov 2007, 09:30
