I can't seem to do this - I have the toolnix toolchain and currently am having some success creating TS files
using mmg.exe and TSmuxerGUI but nothing I can do seems to get chapters or searching to work.
Can anyone explain or point me at a FAQ with known working solutions for this please?
cheers
Results 1 to 11 of 11
Anything except on a PC basicaly.
Take a standard DVD - turn it into MKV with say - MakeMKV or use MKVmergeGUI
create start time and chapter names data save it to the MKV file
Playback on device such as TV or Bluray and chapters are not recognised and (on my LG player at least)
the fast forward searching doesnt work.
Try encoding into .TS and still not recognised.
Has anyone produced a short file with chapters that can be downloaded and used as a test
to check hardware playability maybe ?
A HOWTO on chapters/search functions in MKV/TS files would be very welcome.
A search here reveals many people asking and no actualy working responses I can find. -
TS cannot contain chapters. Read a bit more about MKV container: it supports a few types of chapters. It can be that your player doesn't recognise one or all of them.
Yes I wondered if it was my player at fault which is why I was asking about an example file.
However I now know it is not the player as commercially produced files seem to work.
For example .TS files generated by the Humax HDR Fox T2 will play and seek correctly.
It seems clear that the collections of applications such as mmg.exe TSMuxer etc do not correctly handle
whatever it is that controls chapters and searching.
I have taken your advice and read up on MKV and it clearly states that 2 types of chaptering are supported
and therefore should work - but dont.
It mentions nothing about forward/reverse seeking at all as far as I can see which would explain why that doesnt
work either.
Interestingly this searching issue seems to be a long standing one always claimed to be a hardware issue and yet
it clearly isn't. It is the applications generating the files that are at fault otherwise my freeview box would not be able to generate files that do work.
As all the applications are so split up and use so many "other" applications to do stuff I dont know who needs to fix this.
The real problem of course is the totally absurd number of formats for everything. -
Get a better media player that can fast forwards most formats.
You wont find a software that makes ts files exact as the humax hdr does. -
I know how to extract chapter.txt from a BD or more precisely from a MPLS file.
But from a .ts file? how can I extract chapters?
What soft should I use?
or better, what script is required?
Thx! -
^ The containers MPG/VOB and TS/M2TS don't have a global header and don't support chapter marks either. Transport streams were created for broadcasting
The format was chosen (and modified) by the Blu-Ray people because of the P.I.P. feature, which is a "secondary program", technically speaking.
Help with TV searching
By kshavo in forum Newbie / General discussionsReplies: 0Last Post: 26th Dec 2011, 10:57 -
searching for a player
By moniia in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2011, 12:19 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 18:27 -
searching for a guide....
By videoman3344 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 04:13 -
Help with converting BBC HD Stream to DVD (Normal methods won't work)
By Killer3737 in forum DVB / IPTVReplies: 3Last Post: 30th Jul 2007, 10:23
