I want to rip a couple of videos from Youtube and then edit them into a montage for a class. I have been able to rip the videos off Youtube using DownloadHelper, so that I can watch them on WMP. I also downloaded FormatFactory 2.70 to convert the files to AVI so I can use them in Wax (or DebugMode Wax? something like that). But for some reason the videos are not displaying in Wax.
If I'm using the wrong programs for any of these steps, please let me know what I should use. I don't need the fastest or best programs, just the ones that work. Thank you.
What video codec did you select in formatfactory?
You might have to try some different and see what works. Like uncompressed, mjpeg, etc. -
Cool. So I changed it to mjpeg and the video is working. The audio is not, but we have improvement. Thanks Baldrick. I think this is a more simple problem because I can rip the sound separately, correct? If you can give me an easy way to do that, I would appreciate it. If not, I've seen a lot of how videos for that so I think I can figure it out.
I use AoA Audio Extractor to get the audio from downloaded YouTube videos in WAV form for working with in Audacity or whatever you plan on doing with them.
If you have Avisynth installed, you can use a script to load almost any video into Wax without conversion to AVI, thus preserving original quality. For example, create a (text) file xxx.avs containing simply the line:
ffmpegSource2("myvideo.flv", atrack=-1)
Then open xxx.avs as a media file in Wax.
This also imports the audio track.
The preview in Wax does not play the audio.
Or do you mean there is no audio in the rendered output?
What audio format are you saving to in project settings?
Newbie: List of Q's, Edit GoPro videos (MP4 and H264) and upload to youtube
By adamsnez in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2012, 16:35 -
My videos are up on youtube, how do they look?
By fuzzblaster in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2010, 20:52 -
ripping videos from youtube in high quality
By aruwin in forum Video Streaming DownloadingReplies: 16Last Post: 12th Sep 2010, 12:32 -
Youtube videos
By mosx13 in forum MacReplies: 1Last Post: 24th Dec 2008, 17:12 -
Youtube videos
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:05
