When I try to convert a .mod to .dv in FFmpegX, it WILL NOT spit out a 16:9 video no matter what we do! So frustrating. Right now our workaround is to throw it back in MPEGstreamclip to convert it to 16:9 (we can't use this to go from .mod -> whatever because of this mpeg2 licensing problem at our school).
ANY HELP IS SO APPRECIATED.
"1. Drop file, 2. Select a Target format (DV), use tabs to check, 3. Encode."
In the Video tab, check that Autosize is set to 16:9. If it isn't, then ffmpegX didn't get the 16:9 aspect ratio from the source file. You may override it, but that will also change the video size, so that needs to be manually set as well, in such a situation: 720x480 for NTSC (29.97 fps) or 720x576 for PAL (25 fps).
Tip: using the "DVD 16:9" autosize option will do these two steps in one go.
Aspect Ratio Problem
By kumaresh in forum Video ConversionReplies: 0Last Post: 5th Jul 2011, 06:42 -
By maccool111 in forum Video ConversionReplies: 6Last Post: 29th Mar 2010, 08:58 -
Aspect ratio problem??
By 3thman in forum Video ConversionReplies: 7Last Post: 28th Dec 2009, 20:42 -
By nlaak in forum DVD RippingReplies: 6Last Post: 4th May 2009, 17:13 -
By Renegade in forum Video ConversionReplies: 8Last Post: 2nd Mar 2009, 21:04
