Results 91 to 105 of 105
Update:
--3.5
-Added: CRF encoding with x264
-Added: TEncoder will now create a temp folder in output when muxing to mp4
-Added: New skins
-Fixed: Video and audio settings didn't resize properly (thx to bug reporters)
-Fixed: Video only encoding with MEncoder failed
-Fixed: Custom general options for MEncoder and FFMpeg weren't saved
-Fixed: Disabling skin caused text to be invisible
-Fixed: Enabling subtitles when no subtitle existed caused problems
-Fixed: Mp4 output with MEncoder was placed in wrong folder
-Fixed: Tray icon didn't work
-Fixed: "Export to script" didn't work
-Fixed: Selecting items from file list with more than one audio track caused problems -
Hi Ozok.
Wanted to point something out, here.
I opened TEncoder to test its ProRes encoding today, and in the "advanced" settings, I saw this window.
My guess is that information displayed here is incorrect,
as the numbers 1-32 are reffering to video quantization (I think).
And the higher the number is, the worst the quality will be (= compressed).
Custom arg in ffmpeg CLI is "q="
I believe it is for "quantization", not "quality".
Can you confirm that it should be the opposite (1 being the best, and 32 the worst) ?
Keep up the good work
The parameter passed to FFMpeg is qscale:v not q when prores is used. But you are right about labels tho. I used the information from: http://ffmpeg.org/trac/ffmpeg/wiki/vfxEncodingGuide
Update:
You can get the latest version from: http://www.downloadbestsoft.com/TEncoder-Video-Converter.html--3.6
-Added: Seperate 32bit and 64bit builds and setups
-Added: Preview button (thx to Bluedraft )
-Fixed: Prores quality option labels were wrong (thx to CyberOtter)
-Fixed: Range editor allowed duration to be zero
-Fixed: "+1 Sec" buttons couldn't increase their range to max -
Thanks Ozok for such a quick update, it is always much appreciated.
Also, ty for the wiki link, I guess I should read this Guide...
Update 3.7:
-Added: A new GUI layout
-Added: An option to disable track id options for mpeg sources with MEncoder
-Added: Subtitle and audio delay step values are now 100 ms instead of 500 ms
-Added: Audio volume option (works for MEncoder only)
-Fixed: Encoding failed with MEncoder if container was mp4 and video codec other than x264
-Fixed: Encoder selection in profile editor wasn't saved
-Fixed: Exit shortcut was "X" instead of "Ctrl + X"
-Fixed: Subtitle font option was ignored
-Fixed: Player will follow subtitle and audio stream selections
-Fixed: "Clear Selected Log" option in "Logs" window didn't work
-Removed: Translations due to GUI changes
-Updated: AlphaControls to 8.53 -
New version 3.8.0 changes:
-Added: Skinning is disabled by default
-Added: An option to copy source files' date/time info to output files
-Added: Support for *.mxf file type
-Fixed: A bug where TEncoder would get stuck even if encoding is done
-Fixed: A bug where checking "Export to script" would cause program to crash
-Fixed: "Apply" or changing selected preset didn't update the summary
-Fixed: "version.txt" errors -
New version 3.9.0:
Download-Added: A tool to merge an image and audio to video
-Added: A tool to dub video with an external audio file
-Added: Many skins
-Added: MP4 muxing while using MEncoder will be done with MP4Box
-Added: File list now shows more information
-Added: "Copy date from source" will now copy last modified date too
-Added: An option, under "Help" menu, to create log archive in the desktop
-Added: Main window is now a bit larger as default
-Fixed: Program would crash when muxing to mp4 using MEncoder as encoder
-Fixed: Subtitle and audio delay values weren't saved properly
-Fixed: Applying a profile didn't update video size option
-Fixed: Video size option wasn't saved
-Fixed: Profile editor would ask to save profile even if nothing was changed/added
-Fixed: Scroll bars in logs window weren't visible
-Fixed: Enabling skins didn't apply hue and saturation options
-Fixed: Enable/disable skin options was not saved
-Fixed: Profiles created by the user couldn't be deleted
-Fixed: "Copy date from source" option wasn't saved
-Fixed: "'' is not a valid integer value." error
-Fixed: Couldn't add files without an audio stream
-Fixed: A few UI related problems
-Updated: FFMpeg -
@ozok - what is that avatar from?
It's reminding me of something out of the old B&W Buck Rogers (1930s) or Flash Gordon...? -
New version 4.0.0 changes:
Download location.-Added: Video downloader
-Added: Total progress will be updated more smoothly
-Added: MP4Box progress will be shown
-Added: A tool to create gif image from video
-Added: An option to disable trimming
-Added: Audio track option won't be used for mpeg sources as default
-Fixed: Subtitle position wasn't used
-Fixed: Duration info in the file list wasn't updated after trimming
-Updated: FFMpeg
Prefer portable version if you don't want to deal with software offers. -
Hi Ozok
Nice & frequent program updates these few months !
Still, i got a question :
I enjoy the subtitling feature of TEncoder, but i can't manage TEncoder to hardcode my SSA properly.
More details :
I got some specials "styles" in my SSAs subs files (fonts/color/positionning...), but once I try to harcode them with TEncoder, it seems that the build-in subtitling options of your program prevails on all the styling in the SSA.
Any way to prevent that and make TEncoder hardcode the subs taking ONLY the styles options from the SSA files itself ?
Thanks !
DVD slideshow GUI - development thread.
By tin2tin in forum ProgrammingReplies: 1872Last Post: 28th Aug 2018, 18:08 -
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 13:39 -
Full FFMpeg/Mencoder gui?
By TSJNachos in forum Video ConversionReplies: 14Last Post: 20th Apr 2014, 10:45 -
FFMpeg only using 1 Thread even with -Threads 2
By maurik in forum Video ConversionReplies: 3Last Post: 8th Jul 2008, 08:55 -
Is SimpleDivx (Mencoder) multithreaded)...which encoders are?
By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 03:28
