TEncoder is a multithreaded gui for ffmpeg, mencoder and mplayer.
If you want to translate TEncoder to your language, please contact me.
Features:
-Run up to 8 simultaneous processes and/or make FFMpeg and Mencoder to do internal multithreaded encoding.
-Hard-code subtitles with same name as video using Mencoder
-Do two passes to improve quality
-Download videos from YouTube etc
-Pass custom options to encoders
-Extract audio or video
-Extract parts from file
-Convert audio files (mp3 to aac etc)
-Select audio track from files with multiple audio tracks
-Extract jobs to .bat file so they can be run later
-Preview files with all options applied
-Edit/create presets
-Works under Wine
-64bit support (FFMpeg only)
Screenshot:
Downloads:
You can download it from here: http://www.downloadbestsoft.com/TEncoder-Video-Converter.html
TEncoder downloads version file from Dropbox. No information is sent during that process.
Any suggestions, criticisms etc are welcome.
				Results 1 to 30 of 105
	I'm looking forward to 1.4. I'm using 1.3 now. This may seem like a dumb question but I know there's a setting to encode say 5 or 10 minutes of the video for testing. I just can't find where the enter the number. Can you tell me which button to press to get to the setting?
 Thanks for the tool. I often use it to transfer video to another container changing only the audio encoding so my set top box will play it.http://milesaheadsoftware.org/
 Fully enabled freeware for Windows PCs.
	I haven't looked at this program, but there probably isn't a button for that switch. If every switch had a button, the GUI would be cluttered and unusable with 1000's of buttons
 You would probably enter the command in the "custom video options" command line box
 In FFmpeg, the command is -t for duration and -ss for start time
 So if you wanted to encode 10 seconds , starting from 01 second in (this would encode from 1second , lasting 10 seconds, to the 11th second)
 -t 00:00:10 -ss 00:00:01
	I confused this with another front end that had time in minutes input box. Thanks for the ffmpeg params. http://milesaheadsoftware.org/
	Tried both Installer and Portable 1.4.
 Running the program pops up an error dialog
 Cannot find sub style file. There will be a problem with Previews.http://milesaheadsoftware.org/
	Hi all
 There is a new version 1.4.
 What's changed:
 -Moved: Custom options, two pass and subtitle options to "Extra Options" window
 -Added: Deinterlaceing
 -Added: TEncoder will remember its last position and state
 -Added: Custom audio and video options
 -Added: Total progress is now updated smoothly
 -Added: Open output folder option to post-encode options
 -Added: Files that do not exist will be removed from list before encoding starts
 -Fixed: Temp. folder could not be cleared if encoder log keeping was off
 -Fixed: Flv, m4v and m2v files could not be opended sometimes
 -Removed: Some of the skins
 -Updated: AlphaControls to 7.55
 -Updated: MediaInfo to 0.7.51
	The preview does work. Just an errant error dialog.
 One other thing I noticed. I often repackage .mkv as .mp4 and only encode the audio to AAC since my WD set top box likes that better than .mkv most of the time.
 Even if I set container to MP4 in the drop-down, have video set to Copy and AAC for audio, in the output folder the file still has .mkv extension. Just seems odd. I think I did see it change to .mp4 once or twice. But I haven't figured out what the factor is to ensure the extension change.
 I tried such a repackage to .mp4 yesterday with 1.4. Process and play went as expected. http://milesaheadsoftware.org/ http://milesaheadsoftware.org/
	This seems strange.
 Is the created file a MP4 or MKV file? Maybe extension is wrong.
 Can you export command lines into .bat script and send it to me so i can find the problem?
 In order to do that under "Extra Options" select "Export to script". Next time you run encoding process, a .bat file will be created under script folder.
	Ok, I think I have it now. After loading in the stuff and making the settings I want, if I then hit Apply button it seems to want to output .mp4. Once I'm used to it I'm sure it will run gang busters.  http://milesaheadsoftware.org/ http://milesaheadsoftware.org/
	Just a positive observation. In the past I used TEncoder to move video to another container, just processing the audio. But I had only done single files. Last night I did 11 videos in batch on my dual core!! It zipped right through 'em!! The program really shines when used in batch mode!! I can see I'm going to be using TEncoder a lot!!  http://milesaheadsoftware.org/ http://milesaheadsoftware.org/
	In 1.4 I don't see any option to choose a skin. http://milesaheadsoftware.org/
	@MilesAhead
 Yes skins were removed with 1.4 but they will be back with 1.5.
	Good enough. Thanks for the reply.  http://milesaheadsoftware.org/ http://milesaheadsoftware.org/
	I do keep encountering situations when wrapping a single video in another container using v. 1.4 where the new container extension is not used. As I mentioned before .mkv output that's supposed to be .mp4 can end up in the output folder as .mkv. I tried hitting Apply Button a bunch of times, using the drop down to set the container again, adding the video file before/after doing all this stuff. But on occasion it just stubbornly keeps the old extension.
 I know I can just retype the extension to what it should be. But it's baffling why it's happening.Last edited by MilesAhead; 19th Dec 2011 at 18:14. http://milesaheadsoftware.org/
	That's really strange. Can you lead me step-by-step so i can reproduce the problem?
	Only load one .mkv. Set container to .mp4. If the output file doesn't keep the .mkv extension then it's something intermittent and I don't so how I could reproduce it. The only time I did a batch run, the output files were named correctly. So I suspect it happens when doing one-offs.
 Usually I encode audio while just using Copy for video, if that's a clue.http://milesaheadsoftware.org/
	I still couldnt reproduce the problem :S
 Please make sure before you start encoding container is selected as "mp4" because extension is generated from that information. If you are using a preset, again, check for container option for that preset.
	Guess it's just one of those quirky type things. Not a big bug. Just thought I'd mention it. http://milesaheadsoftware.org/
	Hi all!
 There is a new version 1.5
 PS Please note that this version BETA which means it has experimental features.--1.5 BETA
 -Added: 5.1 channel support
 -Added: Option to preserve aspect ratio
 -Added: Encoder changes according to selected video codec
 -Added: Options to select between multiple audio and subtitle tracks for each file
 -Added: Option to specify encoding range (in sec.) for each file
 -Added: Encoder output is shown during encoding process
 -Added: Skins
 -Fixed: AAC encoding problems with MEncoder
 -Fixed: A few minor bugs
 -Improved: Properties windows shows more info now
 -Improved: Some UI changes
 -Updated: AlphaControls to 7.57
 -Updated: MediaInfo to 0.7.52
 -Updated: FFmpeg to N-35966-g1d0ae92
 -Updated: MPlayer and MEncoder to Sherpya-SVN-r34401-4.6.2
 -Updated: libfaac to 1.28
	Hi all
 There is a new version 1.6
 --1.6
 -Added: Option to select audio or video only encoding
 -Added: Support for audio encoding (mp3 to aac etc.)
 -Added: Support for Webm (VP8 + OggVorbis)
 -Added: Splash Screen
 -Added: Option to apply range settings to all files in the list
 -Fixed: FFMpeg encode range misscalculation
 -Fixed: Command lines were not shown in logs
 -Fixed: Default skin was not Ubuntu
 -Fixed: FFmpeg Mpeg4+AAC+Mp4 problem
 -Improved: Encoding screen is merged with main screen
 -Updated: AlphaControls to 7.59
	Hi all,
 There is a new version 1.7
 --1.7
 -Added: Player
 -Added: Range Editor
 -Added: Option to specify subtitle delay for each file
 -Added: Option to specify audio delay for each file
 -Added: Audio and video bitrates can be entered manually
 -Added: 4 more aspect ratio options
 -Added: Installer can create folder group in start menu
 -Added: MPlayer log
 -Added: Two new skins Lucy and Air
 -Fixed: MEncoder encode range misscalculation
 -Fixed: MEncoder no audio problem
 -Fixed: None as video and audio codec warning
 -Fixed: Subtitle and audio problems if file removed because it doesn't exist
 -Fixed: Drag and drop did not work
 -Fixed: Encoding time was not accurate
 -Removed: Splash screen because it causes problems with drag and drop
 -Improved: Some minor UI changes
 -Updated: MediaInfo to 0.7.53
 -Updated: AlphaControls to 7.60
 -Updated: FFMpeg to git-6833fe4Last edited by ozok; 9th Feb 2012 at 12:10.
	@thezanny no i don't think so.
 I have never worked with blu-ray discs before but I will look into it.
 By the way, you can ONLY burn-in external subtitles with TEncoder at the moment.Last edited by ozok; 11th Feb 2012 at 07:51.
	Hello,
 re-encoding a BluRay MKV/DTS file to smaller resolutions but I keep getting black bars. How do I keep original aspect ratio when selecting your pre-defined resolutions.
	There is a new version 1.9
 --1.9
 -Added: Option specify custom video width and height values
 -Added: Audio extraction now produces valid files
 -Added: A new skin: LightBoard
 -Fixed: 1440x1080 resolution was passed wrong to the encoders
	Update:
 --2.0
 -Fixed: Didnt keep encoder logs if "Nothing" as post-encode option wasnt selected
 -Fixed: FFMpeg could not do two pass h.264 encoding
 -Fixed: m2ts files could not be draged and dropped
 -Fixed: Custom args were not passed correctly
 -Updated: AlphaControls to 7.65
 -Updated: MediaInfo.dll to 0.7.58
 -Updated: FFMpeg to N-41074-g9c27f29
  DVD slideshow GUI - development thread.By tin2tin in forum ProgrammingReplies: 1872Last Post: 28th Aug 2018, 18:08
  AVANTI - FFmpeg/Avisynth GUI (support thread).By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 13:39
  Full FFMpeg/Mencoder gui?By TSJNachos in forum Video ConversionReplies: 14Last Post: 20th Apr 2014, 10:45
  FFMpeg only using 1 Thread even with -Threads 2By maurik in forum Video ConversionReplies: 3Last Post: 8th Jul 2008, 08:55
  Is SimpleDivx (Mencoder) multithreaded)...which encoders are?By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 03:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
