Update:
Results 31 to 60 of 105
Update:
--2.1
-Added: Cropping (beta)
-Added: Option to disable skinning (thanks to zo-ni)
-Added: Option to do CBR video encoding with FFMpeg
-Fixed: Mencoder hard-coded subtitles eventhought subtitles were disabled (thanks to gnaw)
-Fixed: A few visual problems (thanks to gnaw)
-Fixed: Post-encode action value could not be saved -
Hi ozok,
thx for this great program.
Still, i've got 2 questions :
1/
As i'm using Profile Editor to create my own Profiles, I only found how to create new profiles, or "edit" the existing ones.... but...
is it possible to DELETE a profile ? (like the ones i feel i'll never use, etc.)
2/
Another profiles related question :
I've drag&dropped 3 different video files i'd like to convert, but, i'd like to use a different profile for each one.
How can i apply a different profile for each file ?
(is it possible yet ? Incoming feature ?)
thx for ur help
Quick Edit :
I just noticed that once u press the "Refresh" button in the Profile Editor, u cannot acces any existing profiles in the main window anymore...
Maybe it's a bug, maybe i'm doing something wrong, but i just tried multiple times, exiting/relaunching TEncoder : this problem keeps happening. So i report
1) No not at the moment but i'll try to add that ASAP. Meanwhile, you can edit profile file manually to remove profiles. It is located at "C:\Users\USERNAME\AppData\Roaming\VC" for windows 7 users. Open it with your text editor, it is an ini file.
2) Again, no not at the moment . TEncoder works as batch encoder, so it will apply same options to all files in the list. Maybe in the future.
Yes, it seems you found a bug, thanks. I'm working on it. -
Gratz for version 2.2 !
Things keep getting better. Looking forward for future improvements
Resp to below :
Dont sweat it, i'm just glad you could fix it
Update:
--2.4
-Added: Video "Direct Stream Copy" is going to use selected container
-Added: A few minor UI changes
-Fixed: Selecting Huffyuv disabled all video settings (thx to pintcat)
-Fixed: Huffyuv resizing, aspect ratio etc problems with FFMpeg
-Fixed: FFMpeg is default encoder for Huffyuv now (thx to pintcat)
-Fixed: Audio extraction may not work properly in some cases
-Improved: Audio codec detection
-Updated: AlphaControls to 7.68
-Updated: FFMpeg to git-070b0e1 -
Update:
--2.5
-Added: Support for Speex (FFMpeg only)
-Added: About 840 device presets (old presets will not work!)
-Added: several new skins
-Added: Support for rmvb files as input
-Fixed: Encoding failed if aspect ratio was forced with some video codecs
-Fixed: TEncoder crashed if "Close TEncoder" was selected as post-encode option
-Fixed: Settings weren't saved if "Close TEncoder" was selected as post-encode option
-Fixed: Video and audio summary problems
-Improved: Audio codec detection (FLAC)
-Updated: MediaInfo to 0.7.60
-Updated: FFmpeg to git-cb3591e -
You might want to add Opus support additionally/instead since Speex has been discontinued in favor of Opus. see: http://www.speex.org/Added: Support for Speex (FFMpeg only)
Update:
--2.6
-Added: User will be warned if given bitrate values are not numeric
-Fixed: Some presets caused size edits and size list to show invalid values
-Fixed: Audio track selection was ignored if "None" video codec was selected
-Fixed: A few UI problems (thanks to Zoni)
-Fixed: In rare cases, TEncoder could not be minimized
-Fixed: Default skin was wrong for portable version
-Updated: AlphaControls to 7.70
-Updated: FFmpeg to git-bbe9fe4 -
Update:
--2.7
-Added: Support for 3gp container
-Added: Video options won't be passed if source is audio file
-Added: Some UI changes to "Logs" and "Settings" windows
-Fixed: "Canvas does not allow drawing" errors
-Fixed: Audio to audio convertion failed
-Fixed: Wrong file extension if video options were set for audio only source
-Fixed: Flickers due to excesive output from backends
-Fixed: Errors occur when Logs were created
-Updated: AlphaControls to 8.01 Beta
-Updated: FFMpeg
-Updated: MPlayer and MEncoder
-Updated: JVCL to 3.47
-Updated: MadExcept to 4.0.5 -
Update:
--2.8
-Added: Option to make TEncoder delete unfinished files
-Added: Custom arguments for MEncoder and FFmpeg are seperated
-Added: Progress will be shown properly while adding folders
-Added: Preview mode for audio only sources
-Added: "Preview" window will show file's name in its title now
-Added: Preview progress will be shown in taskbar
-Added: Two new skins "WEB2" and "Subway"
-Added: File being process will be shown during adding process
-Fixed: Unnecessary warning if saving script enabled with MEncoder as encoder
-Fixed: "Abort" button was disabled in some cases
-Updated: AlphaControls to 8.02 -
Update:
-2.9
-Added: Support for audio codec Opus
-Added: Support for .opus files
-Added: Decreased main window dimensions (will reset position info)
-Fixed: Custom arguments were not passed if codec is "Copy"
-Fixed: MEncoder "Direct Stream Copy" container problem
-Fixed: Minor UI problems
-Updated: MPlayer and MEncoder to SB41
-Updated: MediaInfo to 0.7.61
-Updated: FFmpeg to latest from ffmpeg.zeranoe.com -
Update:
--3.0
-Added: 64bit ffmpeg will be used when it's possible
-Added: Shutdown PC, log off or reboot post-encode options
-Added: Option to run single process when video codec is x264
-Added: CPU usage indicator
-Added: Tray icon and balloon hint
-Added: New skin "Zest"
-Fixed: Audio summary info was wrong in some cases
-Fixed: Reseting settings caused wrong skin selection
-Fixed: Speex files could not be added
-Fixed: BAT files with MEncoder as encoder could not start
-Fixed: Default output folder is program folder for portable version
-Updated: FFmpeg to 11-05-2012 from ffmpeg.zeranoe.com
-Updated: MPlayer and MEncoder to SB42
-Updated: AlphaControls to 8.03 -
Hi ozok
I am interested in trying TEncoder as I like the look of it. However after installing the current version (V3) I have discovered it will not handle AVS (avisynth) files. It renders the audio but not the vision. Avanti opens and encodes these files, as do a number of other programs without problems.
Is there anyway that I can get TEncoder to handle these files.
I want to be able to encode to DVD (standard) and Bluray (up to 1920x1080x25i) using both Mpeg2 and H264 codecs.
It would also be good to be able to encode to AVCHD up to 1920x1080x50P!!!
Also can it encode to WMV3?
Thanks in advance
Goorawin -
I really like the CPU meter on 3.0!! Saves me running Core Temp in the corner. Plus now I don't have to do the math adding up the percentage usage for each of the 4 cores.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
Hi Ozok
Thank you for your reply. Attached are the log files. MEcoder does work with avs files however the quality is very poor and changing the bit rate setting has no effect. I would prefer to use Ffmpeg as I know many of the custom arguments. This will be necessary as TEncoder does not appear to have any interlace options (why not?).
The reason I was interested to have WMV3 as an encoder is because it is the only format (WMV2 will not work) that tricks many TV's and players to play 1920x1080 at 50P. AVCHD will do it but only from DVD disc, which do not hold enough data.
Anyway hope you can figure out the AVS issue.
Thanks -
I think i figured why FFMpeg won't accept avs files. TEncoder tries to decide if source file is audio-only in order to pass audio options only. Since avs files have no video streams, it sees them as audio files. I've made some changes and will post a modified TEncoder.exe shortly.
Replace this exe file with your TEncoder.exe. Make sure you create a backup.Last edited by ozok; 16th Nov 2012 at 16:31.
Hi Ozok
Thank you for the uploaded file however I am current on an XP Pro computer and win zip does not know the compression used.
Any suggestions?
I have to go shortly and will be away for 2 days.
Thanks -
Hi Ozok
That works, great!!!. I will do some serious testing next week.
The preview does not work, is there any way to get that to work?
The AVS plays in Media player classic, TMPGEnc and others.
Thanks again for such a quick response and what looks to be a great simple program.
Goorawin -
@goorawin is your OS 64bit? There might be a conflict between 64bit FFmpeg and 32bit avisynth.
I have WD HDTV for USB gen1 set top box. I can't seem to figure out the TEncoder 3.0 presets. Three out of the 4 listed for WD say (mkv) but when I select them and hit Apply Button, none of them have MKV as the output container type. Some have AVI, some have MP4. It leaves me doing the settings by hand. Is there something obvious that just goes over my head? Granted .mp4 files give good quality for the bit rate, but I cannot seek the video in my WD player using .mp4 or .m4v files. For that reason I'm trying to encode to AC3 audio and MKV container. No chapter support but at least I can hit the FF button, then Next to jump ahead in 10 minute chunks.
This program really seems to be coming into its own. Great progress. I enjoy using it.
DVD slideshow GUI - development thread.
By tin2tin in forum ProgrammingReplies: 1872Last Post: 28th Aug 2018, 17:08 -
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 12:39 -
Full FFMpeg/Mencoder gui?
By TSJNachos in forum Video ConversionReplies: 14Last Post: 20th Apr 2014, 09:45 -
FFMpeg only using 1 Thread even with -Threads 2
By maurik in forum Video ConversionReplies: 3Last Post: 8th Jul 2008, 07:55 -
Is SimpleDivx (Mencoder) multithreaded)...which encoders are?
By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 02:28
. Thanks for the information.
