here is the problem
when i dl the file i played it in wmp and it played okay, i flicked through the film until the end. the words just start and then it finishes.
i have now tried to play it in windows and it is telling me the class is not registered.
my problems is this i tried to convert to vcd using tmpgenc but at about 2.30 the screen goes black and then it converts faster due to there being nothing on screen. i have tried to take the audio out using audiodub but it
says something likeit has to rekey the fileand then only gives me about 8 minutes of audio?. i then tried divxfix and that tells me there is 2 errors but when it gets to the end it tells me there is and i/o error and never actually fixes the problem.
i am converting to vcd but if the file is the svcd version would that be the problem
any help appreciated
cheers eminem
i have had this problem with one other file enemy at the gates but i just dl/ed the file again and that file worked.
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 20:09 -
Looking for a MONSTER editing/converting/burning program. Help?
By gastrof in forum Newbie / General discussionsReplies: 5Last Post: 5th May 2008, 18:55 -
Converting a Home DVD to AVI - but not divx?
By sterankin in forum Video ConversionReplies: 4Last Post: 16th Feb 2008, 12:52 -
best software for converting dvd to avi, divx etc ???
By geronemo in forum Newbie / General discussionsReplies: 4Last Post: 15th Nov 2007, 13:48 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 15:47
