Hi I was wondering if there is software available to burn multiple DVDs to one Blu Ray disc without quality loss.
For example say I have disc 1,2 and 3 of some TV show, instead of burning each one seperatly to a DVD disc, can they all be burnt to a Blu-Ray disc and a selection menu at the start can let you chose which disc you want to load?
Cheers.
Can you author menus using this software? I have a bunch of mkv files I'd love to author on to a single blu ray disc.
I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone. -
Multiavchd will author with motion menus as well as still menus.
Just a word of warning - while multiAVCHD works great for most BD players, a very small number simply cannot play anything it creates. I own one of those players (Momitsu). A few others are pretty fussy and will only play discs created in specific ways. You might want to try your first one with a re-writable BD disc just to be sure the settings you used work OK in your player.
I bought a philps blu-ray that plays mkv from burned blu-ray and usb thumb drives so i dont need to author blu-rays anymore.They also dont have to be blu-ray spec either.
Multiple DVDs on a Blu-Ray Disc
By rstrom2008 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2012, 06:34 -
Multiple Aspect Ratios on One Disc
By gorcq in forum Authoring (DVD)Replies: 7Last Post: 20th Dec 2011, 21:35 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 15:50 -
multiple vids on one dvd disc
By johnnyboy1908 in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 02:34
