  1. I have no porblems opening normal wmv files, but when i try with wmv using advanced profile, i saw black screen with "missing coded". Anyone knows how to open this wmv files with Virtualdub?
    Medianfo shows:
    Format : VC-1
    Format profile : AP@L1
    Codec ID : WVC1
    Codec ID/Hint : Microsoft
    Description of the codec : Windows Media Video 9 Advanced
    Anybody knows where can i get driver for this format?
    Anybody knows an alternative to virtualdub to reencode this videos to avi?
    Thanks in advance.
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Medianfo shows:
    Format : VC-1
    Codec ID : WVC1
    Thanks in advance.
    Install FFDSHW. Open DECODER tab and config like as:
    Only this.
    Claudio
    Mar 2008
    To use the above codecs, probably will also have to have the Virtualdub directshow source driver.
    www.virtualdub.org/beta/DShowInputDriver-0.91.zip
    Download the above, extract the vdf file and place it in the Virtualdub plugins folder.
  4. I could open them using another way, simply installed Windows media player (i not had it installed becaise i´m using windows server 2008) and now wmv files open good with wmv plugin.
    Thanks for your answes.
    Mar 2008
    I thought you wanted to convert them ?
  6. Originally Posted by davexnet View Post
    Yes i want to convert them to avi
