Hi guys this is my first post here. Well I just got and HD PVR and it came with the software Total Media Extreme 2. TME has been really healpful but I noticed the videos recorded with it have black lines. The thing is I don't want those black lines on my videos and I don't wanna render them cuz it takes a lot of time and since HD PVR already compressed the video inside of it rendering it will make it lose more quality. I see no option on TME to crop the video before capturing it like VirtualDub can do. That's why I tried VirtualDub with HD PVR and it does recognize the HD PVR but I get nothing in the preview of the program and when I try to record it give me an error. So my questions are: Its possible to record from HD PVR using VirtualDub? Is there any other program that let me edit the frames that the HD PVR will be recording? I don't wanna reder the video files after I recorded them. Thanks in Advance.
The video that comes from the HD PVR is already compressed. The only way to remove black borders is to decompress the video, crop the black borders away, then recompress it. You cannot do this in real time with any software I know of.
VirtualDub cannot capture from the HD PVR. It's designed for devices that capture uncompressed video. -
Yes. The best way is to use DgAVCIndex and an AviSynth script with DgAvcSource(). If you have all the correct DirectShow filters installed you can use the DirectShow source plugin for VirtualDub. For a DirectShow file reader/splitter try using Haali. For AVC/AC3/AAC decoding ffdshow.
Hauppauge 1212 HD-PVR
By tomfranklin in forum LinuxReplies: 4Last Post: 28th Sep 2010, 10:33 -
Xbox 360 - Hauppauge HD PVR 1212 - Please Help
By twblindv2 in forum Capturing and VCRReplies: 1Last Post: 14th Apr 2010, 16:29 -
hauppauge hd pvr 1212 Capture Issues
By jwack in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2009, 20:17 -
How do you setup the ir blaster for the hauppauge hd pvr 1212?
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Aug 2009, 09:42 -
hauppauge HD PVR 1212 workflow
By unplug in forum EditingReplies: 2Last Post: 5th Sep 2008, 15:21
