Sorry if this should go in the photo board, this just seems very general so thought I'd ask here but mods feel free to move it if needed.
So anyways, need help, I know very little about scanning/photo editing so bear with me.
My tower crashed and I got a new one but the HP software for my print/scan/copy machine (Photosmart C5580) won't load on Windows 7 (don't know why, I heard W7 will take everything but the message says op sys not compatible and won't let me go any futher with installation of it & it's only a couple years old, I know, a couple of years in this stuff is big but it's not from the 70s or anything).
I was still able to hook it up and scan/print/copy from it but I used to descreen jpegs I'd scan through the HP software and I can't find a screening option on anything else I have.
So between Photoshop Elements 7, ReadIris Pro 11, Windows Photo Gallery & Viewer, Movie Maker, Media Center & Paint, does anyone know if any of these will descreen a jpeg scan (I think the only one of these I can use to scan is ReadIris but I tried this (and "Windows Fax & Scan" but to no avail) maybe under a different phrase or something (I've looked through the menus of each but can't find anything remotely close but hopefully someone here can say "it's staring (me) in the face under (this name)".
If not, can someone recommend reliable but cheap software that will definitely do this that I can get?
Thanks in advance for the replies.![]()
There are undoubtedly specific Photoshop filters for descreening (I used to use Extensis Intellihance) but you can do it using a Gaussian blur -- adjust the parameters until it's just strong enough so the screening is gone, and then you might do a sharpen to reduce the softening that the blur made.
Otherwise : About 20,700 results for photoshop+descreen
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
VideoStudio 8...will it support "motion jpeg"?
By utamav91 in forum EditingReplies: 0Last Post: 22nd Nov 2010, 23:35 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Tool for converting to "Motion JPEG 3.2.4"
By srt842 in forum Video ConversionReplies: 4Last Post: 11th Oct 2008, 08:36
