I have a Cannon Vixia HF R10 and I have no problem getting video from the camera to my pc but that's all I'm able to do. when I try to edit or save imagemixer 3 crashes every time.
Joseph
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 10 of 10
welcome joseph7384
no computer specs listed but if windows 7 is being used right click om the shortcut to imagemixer 3 and set compatibility mode to xp + sp2 and try again -
Any codecs or codec packs not native to the system installed ... Haali Media Splitter can trigger the fault
K ... go here ... unpack the zip file and run InstalledCodec ... then use ctrl + a (select all) ... then ctrl + s (save as txt).
zip up the newly created txt file and upload the file ... just below where you post messages is the buttom "upload files/ manage attachments" -
Ok, done.
I think the second attachment is the correct one.Last edited by joseph7384; 23rd Oct 2011 at 10:04.
I think the above attachment is wrong but I can't seem to upload the correct one.
This should be the correct one.
Canon FS10 lost my pixela Imagemixer CD
By wxfreak in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2011, 22:47 -
No preview in ImageMixer 3 SE Ver.6
By P.J in forum EditingReplies: 0Last Post: 5th Dec 2010, 10:16 -
Tranferring Video from camcorder to PC using ImageMixer 3 Version 6
By kramericaman in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2010, 16:17 -
PIXELA ImageMixer™ 3 SE for Canon HG20
By kacper in forum CapturingReplies: 0Last Post: 2nd Apr 2010, 09:12 -
Does anyone use IMAGEMIXER ???? ....i have a problem
By citrusdog in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 08:49
