Results 1 to 19 of 19
  1. I am trying to call MediaInfo from within a Visual Basic program in order to obtain the video and audio information about a video file. The intention is to store this data in an access database record linked to the video clip. Does anyone have any info on the format and parameters required to call MediaInfo? Thanks
  2. Member DB83's Avatar
    Jul 2007
    That would not help as you still could not parse that data to import in to your access db fields.
    Easier to write your own code to parse the video header(s) - I did a quick google and found info on mpeg and avi(apparently with full vb code) headers so it should all be out there.
    Avi details here (links to vb code):
    http://www.planet-source-code.com/vb/scripts/showcode.asp?txtCodeId=46648&lngWId=1
    Some info in mpeg headers here:
    http://www.codeguru.com/forum/showthread.php?t=235226
    Oct 2010
    England
    I don't know anything about VB/access, but it should be possible to get mediainfo to report details on a file in a custom format of your choice. Maybe a comma separated list would be suitable? Something like:
    video.mp4 , 01:20:00.00 , 16:9 , 640 , 360 , h264 , ac3 , 2 , 44100
    which would correspond to:
    filename, length, aspect ratio, width, height, video codec, audio codec, audio channels, audio sampling
    This document has some formatting examples:
    http://umibe.googlecode.com/svn-history/r8/trunk/umibe/resources/MediaInfo/Contrib/CLI_Help.doc
    If this is what you're looking for, I can provide some specific examples. Just give a list of what information you want and the way it should be formatted.
    There seem to be some bugs with getting mediainfo to format the output which I haven't found a way round. This might be an issue, depending on what you want to do exactly.
  4. Well let me give the details. I have written an MS-Access VBA application which scans given folders to find video clips and gets the file specific data provided by Windows such as file date, file size, etc. These attributes are stored in a row of the table. However for a video clip database this is not enough. So I am looking for a way to run the MediaInfo utility for the clip concerned and get the video and audio data from MediaInfo to store in the same row. For this purpose I execute the MediaInfo CLI from within the VBA module. Up to this point all runs well. Now I am looking for a way to grab the results that show up at the DOS CMD panel and store them. MediaInfo CLI has an output option that does not work. If I use the output parameter of DOS CMD it creates an empty text file. This is the problem.
  5. Member DB83's Avatar
    Jul 2007
    I really should not reply to this forum before I have my first coffee. So my apologies for the original 'blast' even tho the comments about the links I posted do still seem valid.
    I clean forgot about the command-line version but I do wonder if that is the best approach. The .dll can also be accessed (pardon the pun) from within vb (versions 5 and 6) and that should return the data in a form you can then control.
  6. I considered dll version. It needs to be registered using regsrv32. I tried many times an error message comes and it can not be registered.
    ed.
  7. Member DB83's Avatar
    Jul 2007
    I took a closer look at the CLI options. The following will give you a full listing of the info of the file saved to [path\]info.txt:
    [path\]mediainfo.exe --logfile="[path\]info.txt" [path\]yourmedia.file (do not forget the quote marks)
    To restrict the output data it seems you have to manipulate the 'inform' parameter with templates
    The output parameter does work but it just outputs hmtl or xml tagged data
  8. Thanks for the input. In fact I have been working on the CLI version. The syntax below works. The info.txt file contains all the parameters.
    "C:\Program Files\MediaInfo_CLI\MediaInfo.exe --logfile=F:\info.txt CVID.avi"
    I experimented a lot with a template file, but helas I could not get it to work. If instead you write the parameters one by one with % signs in the command line as a template then it works. In any case the resulting text file contains the necessary data which I can read in VBA and manipulate. If anyone else hits the same problem I can write down the various syntax options that I tried.
    Oct 2010
    England
    Do you mean the DOS command window literally appears when you run mediainfo from VB? That doesn't seem the best way to do it. I would've thought the only time you'd want to do it that way is when you need to interact with a text based program.
    There's got to be a way to run a program from VB in the background and have any output from it stored in a variable for further use. I've never used VB, but with php (completely different I know):
    PHP Code:
    $data exec("mediainfo --Inform='Video;%DisplayAspectRatio/String%,%Duration/String3%' video.mp4");
    echo
    $data
    Here's a page which has examples on how to execute system commands:
    http://rosettacode.org/wiki/Execute_a_system_command#Visual_Basic
    (no idea if that's the best way to execute a system command)
    It looks like Visual Basic is one of the most complicated examples on there
    Try putting this in a file called 'template':
    Then run:
    C:\Program Files\MediaInfo_CLI\MediaInfo.exe --Inform=file://C:\full\path\to\template --logfile=F:\info.txt CVID.avi
    EDIT: you might have to escape the slashes
    You should get the aspect ratio and duration separated by a comma.
  10. Originally Posted by intracube View Post
    Yes it shows up briefly and disappears.
    I do agree with you. I have seen the Rosetta page. It did not bring much towards the solution.
    Then run:
    I have tried this proposal. No it does not work. The problem seems to be not the structure of the template file but rather the template file option itself. When an output option such as logfile is present the template file option does not work. In fact this is also mentioned in the CLI help document stored in the contrib folder.
    Oct 2010
    England
    Hmm, the following syntax works under Linux:
    mediainfo --Inform=file:///path/to/template --LogFile=/path/to/logfile video.mp4
    note: the syntax is inconsistent. The path to the Inform template starts with file:/// but the path to the logfile doesn't.
    Not sure how this should be adapted to work with Windows.
    The command above (using the template defined in post #9) creates a file which contains the text:
    16:9,00:00:13.400
    One bug I've noticed - if the Inform template contains a 'General;' section, it messes up the output. Only 'Video;' and 'Audio;' sections seem to work properly together.
  12. I got it to work. Here is the command line. This is followed by a space and the path to clip .
    "C:\Program Files\MediaInfo_CLI\MediaInfo.exe --Inform=file://F:\VVV.txt --LogFile=F:\info.txt"
    VVV.txt contains this: Video;Aspect_Ratio=%DisplayAspectRatio/String%,%Duration/String3%
    info.txt contains this: Aspect_Ratio=16:9,00:03:44.800
    Template syntax is not consistent and not properly documented. Most of the effort is guesswork.
    Oct 2010
    England
    Glad you got it working. I might be able to suggest a set of template options if you list what info you want returned, and the formatting.
    mediainfo can return many of the details in a number of ways. For example the aspect ratio can be displayed as a ratio 16:9, or floating point 1.778.
    Changing your VVV.txt to this:
    Video;%DisplayAspectRatio%,%Duration/String3%
    Will output the aspect ratio as 1.778 instead.
    Try running:
    C:\Program Files\MediaInfo_CLI\MediaInfo.exe --Info-Parameters
    for a full list of available parameters.
    I've uploaded the list in case you have problems running this command.
  14. Thanks a lot. I have now extended the template elements in the file. Only the /n/r parameters to get a new line do not work. The others are OK. I have done some more research on this subject. There are procedures to run a DOS command from VBA and then display results in a msgbox. But in most cases when it is possible to get results in a text file then this approach is preferred. Especially in my case I plan to have around 15 parameters in the result. Even if I go for a text string in a msgbox I shall have to parse the string using string functions to display and store the values properly. Thus a text file as output is satisfactory for the purpose.
  15. As I said before Media Info CLI parameter syntax is quite inconsistent. I have the template file as below working:
    Video;---Format=%Format%---Duration=%Duration/String%---BitrateMode=%BitRate_Mode%---Bitrate=%BitRate/String%---Width=%Width%---Height=%Height%---Aspect_Ratio=%DisplayAspectRatio/String%---FrameRate=%FrameRate/String%---FrameCount=%FrameCount%---Standard=%Standard%---ScanType=%ScanType/String%---
    The logfile is:
    ---Format=MPEG Video---Duration=4mn 48s---BitrateMode=VBR---Bitrate=9 168 Kbps---Width=720---Height=576---Aspect_Ratio=16:9---FrameRate=25.000 fps---FrameCount=7205---Standard=PAL---ScanType=Interlaced---
    Sometimes it creates an empty file. Why? I have not figured out yet.
  16. Member Cornucopia's Avatar
    re: empty files,
    Maybe because of NULLs or other non-standard input. Like the field "Standard" - sure, there's PAL and NTSC. And you could probably put 1080p24, 720p60, ATSC in there, but if the file is 400x300, there's no standard. So what should it output?
    [BLANK], "Other", "None", skip the field, or possibly skip the output altogether...
    Too bad you can't poll the DLL by each field individually, then you could control the reaction to non-normalized or unavailable output.
  17. Member vhelp's Avatar
    Mar 2001
    New York
    i don't get it.. what is wrong with importing the DLL inside ms access ? i've done this a few times in ms access--where i wrote several different DLL's in delphi code (math functions) and then imported into access and used those math functions in the delphi dll. course, i was using office 2000 in those tests. if you can't read mediainfo.dll directly inside ms access, then perphaps you can create a front-end dll inside visual basic, and then load that dll inside ms access. you should be able to do the same unless visual basic doesn't create dll's, i don't know since i have/use it. at least one of these methods should work.
  18. Originally Posted by vhelp View Post
    I tried to register the MediaInfo dlls using regsrv32, but I got an error message. They can not be registered. Try to import them they are refused. The template and logfile at least work and I have a handle on them. I managed to get the whole issue working as planned. Of course any other suggestion that can simplify the code is welcome provided that it works and does not require many hours of debugging.
  19. After some testing I found out that MediaInfo CLI does not like filenames with embedded spaces. I renamed the video files suppressing the spaces and the program started working properly.
