Video capture devices available are many with questionable results. I am searching for a quality device that will easily convert VHS tapes to digital formats that can then be burned to DVD's playable on home DVD players. Any experienced recommendations will be greatly appreciated.
Results 1 to 9 of 9
i've always used Hauppauge products, i have 2 HD capture cards and 1 SD card.
HD card # 1: hauppauge colossus
HD card # 2: HD PVR
SD card #1: Hauppuage 250
both work great, use the 250 or 350 for vhs tapes -
also, use the wintv software to cap the video. use a third party video trimmer/cutter ( i use videoredo) im sure there are free ones available.
i think hauppauge bundles some sort of program that can create the dvd for you, if not their are plenty of other programs listed on this site. -
The best capture card in the world will still give you crap if you don't start with an SVHS deck with a line TBC. Spend your money there first.
Thanks for the replies. Do you know anything about Hauppuage's new device "USB-Live2: a USB based video capture device for your Windows PC"? It looks simple enough being a plug-in device to computer and VHS tape player. Do you think it could be used to accomplish my task? Supposedly it is supplied with a program disc? i have a Windows 7 system on a Dell 430 Ultimate computer with 4GB of ram. -
I haven't heard anything about Hauppauge's USB-Live2 here. That probably means it is unremarkable. There are a number of devices like Hauppauge's USB-Live2 with similar features that claim to capture VHS and have the ability to take snapshots. It will probably produce decent results, but that depends on it getting good input.
There is no capture device or capture software that can magically correct a poor signal on their own. Good captures are dependent upon the VCR and other equipment feeding a stable, time-base corrected signal to the capture device.
You came here because you recognize you need advice. Listen to Jagabo's advice about getting an SVHS deck with a line TBC. -
I'm only interested in converting my one VHS collector movie. Perhaps an investment such as recommended would not be worthwhile. Does anyone know of a reputable video conversion company that could reliably convert my VHS movie to a playable DVD? Once again, like video conversion hardware and software offerings, there are many such companies that profess to be able to do this but I suspect many cannot do a quality job and indeed may not be reliable?
Can anyone recommend a company with which they have had good results? -
"Can anyone recommend a company with which they have had good results?"
Haven't used them myself but would recommend: http://www.digitalfaq.com/services/video-conversion-tape-to-dvd.htm
If possible, make as good a copy of the tape as possible before mailing it - things do sometime happen in transit.Andrew Jackson: "It's a poor mind that can only think of one way to spell a word." -
Thanks verify for your reply. I will check out your reference and post on this thread the results obtained if I use them. I like that they are a US based company and appear to have advanced video conversion equipment and experience. Perhaps they can make my desired one time conversion saving me expense and most of all substantial frustration!!
Looking for a USB Video Capture Device I can work with in VB.Net
By Snakebyte1 in forum Capturing and VCRReplies: 0Last Post: 6th Oct 2011, 07:59 -
Video Capture Device - Suggestions
By rancineb in forum Capturing and VCRReplies: 12Last Post: 20th Aug 2011, 19:27 -
Win7 64 bit Video Capture Device
By DuchessofWoking in forum Capturing and VCRReplies: 5Last Post: 15th Feb 2011, 09:24 -
Virtual video capture device?
By plugues in forum Video Streaming DownloadingReplies: 2Last Post: 13th Jul 2010, 19:28 -
help with video capture device config/ stream format
By fergwannville in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2008, 08:12
