To me even that clip you posted, thanks, is block. I'm having to bump up the kbps to 3000kbps, or for movies, at least 2000kbps. By which point I'm wondering what is the point? The resulting files are half to three quarter the size of the original vobs. For storage I may as well stick with vobs for my xbmc setup and go low bit rate divxnfor my mobile media wishes (my android devices).
I was under the impression DivX was supposed to get roughly the same quality in a much smaller file. Mmmm. Disappointed.
				Results 31 to 38 of 38
	Yeah, watching full screen. The blocks aren't too bad, but they're definitely there in the shadows and darker areas, like against the desk and wood panelling in the office. And of course watching it on a 37inch high def tv through xbmc is meh. Maybe I should get something to help with the OCD
	Im not even bothered about HiDef. Just want to transfer the movies to DivX using a lower bitrate to save space as I though DivX could compress a lot better. I see lots of people getting what they say is excellent results, virtually near the original, and they're running half the bitrate or less. Where as Im having to create videos of virtually the same size. Perhaps I shouldn't expect much going lossy to lossy.
 Oh by the way, I watch full screen on my 19" monitor, and attempt playback too using XBMC through a 37" high def TV. Don't join two bits of different sentences together and pretend I've said something I haven't.
	Did you look at your source? It's full of blocks and other crap. What are you expecting? Divx and h.264 get better compression than MPEG 2 when both are starting with a same source. Every time you compress with a lossy codec you get more losses. So compressing an already overcompressed video with another lossy codec is going to make it look worse, not better. Try reencoding your source with MPEG 2 at the same bitrate as the MKV file and see how much worse it looks. You're starting with crap. Crap in, crap out. If the minor blocking in the dark areas is bothering you the black level on your display is probably incorrect. Calibrate your monitor and they'll be barely visible. Last edited by jagabo; 22nd Oct 2011 at 08:20.
	The source was straight from uncompressed DVD (except for the private video). But whether it's a 4 Mbps average VOB or an 8 Mbps VOB, I still get awful blocking/banding whatever you want to call it. You have to get up close, but it really loses it's clarity.
 Now, if DivX isn't designed to handle that, then that's fair enough, but makes a mockery of media streamers unless you just have a load of video that you don't actually care about.
 Ta
 Simon
  What DivX standalone players play "BRRip.XviD" files?By Stealth3si in forum DVD & Blu-ray PlayersReplies: 8Last Post: 10th May 2009, 22:14
  Do hdtv owners use the "fill" mode to get rid of "underscan&By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 20:02
  FASTEST WAY: Divx 1024x576 to Divx "Home Theater"?By GrayStrickland in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 22:03
  TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 12:27
  Choppy "Strobe" results on Divx ConverterBy kirklt in forum DVD RippingReplies: 0Last Post: 29th Jun 2007, 00:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
