Hi,
I've got the SilverCrest DV5300 Camcorder, and I use Adobe Premiere to mix my movies.
When I record with the camera it saves my files as ".AVI". Even though I recorded for 38 mb, the Adobe Premiere freezes whenever I try to upload the .AVI 38 mb file.
Howcome, please?
When I go to File -> Import and choose my file, an alert comes up:
Sorry, a serious error has occured that requires Adobe Premiere Pro to shut down. We will attempt to save your current project.
Results 1 to 9 of 9
avi is just a general name for a container. there are all kinds wacky formats called avi. never heard of a silvercrest cam so i assume it may produce oddball video.
try using mediainfo on a video. put mediainfo into text mode and copy/paste the results here.--
Thx.
Here it is:
General
Complete name : C:\(My path)\20111020172458\FILE0001.AVI
Format : AVI
File size : 35.8 MiB
Duration : 1mn 7s
Overall bit rate mode : Constant
Overall bit rate : 4 424 Kbps
Recorded date : 2011-10-19
Writing library : AMBA
ICRT : 16:42:53
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : H264
Duration : 1mn 7s
Bit rate mode : Constant
Bit rate : 4 001 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.145
Stream size : 32.6 MiB (91%)
Audio
Format : ADPCM
Codec ID : 11
Codec ID/Hint : Intel
Duration : 1mn 7s
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 4 bits
Stream size : 3.12 MiB (9%)
Interleave, duration : 43 ms (1.28 video frame) -
What version of premiere ?
You can re-wrap it in a .m2ts transport stream (eg. tsmuxer) and CS4/5 should be able to accept it . CS3 and below don't have support for AVC video, so you would have to encode to a digital intermediate for editing (e.g. cineform, or some lossless format e.g. huffyuv, ut video codec) -
When my brother saves his project he choose Export -> Media.
I can't choose that in CS3.
Im just about getting CS 5 Family (Will it work??)
And then I'll try the normal way. But will Pro CS 5 >FAMILY< work? -
Baldrick
- How should I save as new avi?
When I save I can't choose type even though i picked AVI in the dropdown menu.
It just says "All Files" when I wanna save... -
Ok, this sh*t is bothering me!!
I know got CS 5.5 Family on my iMac, and still cannot upload my AVI file. And no matter wich program i convert it with, it makes the quality look like a peace of ..
M4V to AVI in VD, when compressed with Xvid, saves with audio out of sync
By kiki hayes in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2011, 10:45 -
Savetube saves - how to play?
By DaniBear in forum Software PlayingReplies: 6Last Post: 18th Apr 2010, 20:19 -
Problems playing Divx / Xvid files on Silvercrest KH 6508
By Onihoshi in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Oct 2008, 16:18 -
DVDFabdecrypter saves as .iso?
By magicfingers in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2008, 09:01 -
Hack Code for SilverCrest Mobile DVD Player KH 6500
By harassedmum in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Dec 2007, 10:07
