Please excuse any stupid questions as I'm a newbie. Anyhow, for days I've been trying to convert a .ts file that was pulled from an HD stream as 1080i with four HD-AAC streams. NO program I tried would convert the file, but I found a program called "DGAVCIndex" that pulled the audio streams and I was able to convert them using NeroEnc to PCM 16 Wavs. I then used TSMuxer to put them together but when I was done I had a playable file in VLC (of course), but WMP would not play it with any sound.
The other day I found "Xmedia Recode" and found it was the ONLY program that would convert the original .ts file, however after two conversions to VOB (10hrs each time) I found even though it was complete in sync you could hear occasional pops and clicks during playback. I'm guessing I'm missing some key setting, but I'll post information on the original file and information on my conversion and hopefully someone can help me. I've tried both MP2 audio (this conversion) and AC3 (last one) to no avail. Perhaps I'm missing a key setting in the program? Again I'm a newbie, but I'm willing to learn.Thanks for any help you can provide.
ORIGINAL:
General
Complete name : H:\GNR2011\GR\GR2011.ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 16.3 GiB
Duration : 2h 19mn
Overall bit rate : 16.7 Mbps
Video
Menu ID : 44512 (0xADE0)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : 27
Duration : 2h 19mn
Bit rate mode : Variable
Maximum bit rate : 24.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : AAC
Format profile : HE-AAC / LC
Muxing mode : LATM
Codec ID : 17
Duration : 2h 19mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Delay relative to video : -277ms
Audio #2
Format : AAC
Muxing mode : LATM
Codec ID : 17
Duration : 2h 19mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Delay relative to video : -346ms
Audio #3
Format : AAC
Muxing mode : LATM
Codec ID : 17
Duration : 2h 19mn
Delay relative to video : -296ms
Audio #4
Format : AAC
Muxing mode : LATM
Codec ID : 17
Duration : 2h 19mn
Delay relative to video : -326ms
CONVERSION:
Complete name : H:\XMedia\GR2011.vob
Format : MPEG-PS
File size : 7.48 GiB
Duration : 2h 19mn
Overall bit rate : 7 683 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Custom
Format settings, GOP : M=1, N=15
Duration : 2h 19mn
Bit rate : 5 994 Kbps
Maximum bit rate : 6 000 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.579
Stream size : 5.84 GiB (78%)
Audio #1
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 2h 19mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 383 MiB (5%)
Audio #2
ID : 189 (0xBD)-129 (0x81)
Format : AC-3
Duration : 2h 19mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Audio #3
ID : 189 (0xBD)-130 (0x82)
Format : AC-3
Duration : 2h 19mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Audio #4
ID : 189 (0xBD)-131 (0x83)
Format : AC-3
Duration : 2h 19mn
Bit rate : 384 Kbps
Bit depth : 16 bits
No, I want a DVD video. I've never heard of AVStoDVD but I'll give it a shot. ConvertXtoDVD won't convert the .ts as the audio streams are an unknown format. I'm hoping for a DVD as well as something I can convert to and then mess around and convert to xvid or whatever but minus the clicks and pops. Would you or anybody else know what settings I need in Xmedia in order to convert it properly?
Xmedia Recode help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 11:36 -
Issue with XMedia Recode Version 3.0.0.5
By jc84 in forum Video ConversionReplies: 14Last Post: 20th Jul 2011, 12:27 -
XMedia Recode v 2.2.1.6
By Bonie81 in forum Video ConversionReplies: 2Last Post: 4th Jun 2011, 14:19 -
Xmedia Recode V. 2.25.8
By pepegot1 in forum Video ConversionReplies: 20Last Post: 29th Aug 2010, 23:58 -
xmedia recode
By csmidha in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 04:34
